i!Weather without comm module
I have a job where there are 5 ENV-VST-C installed and working fine. I wrote my own code for them and bypassed the module.
Now we are adding i!Weather and I need to know if I can use the i!Weather module on it's own without all of the other VST code supplied by AMX.
Has anyone done this successfully?
The answer seems to be that it's all or nothing. I'm currently redoing panels and scrapping my working code.
If you're referring to how AMX has sorta broken its own design paradigm and put non-comm type programming in the .comm module that can get in the way of doing things with the UI, then you are right.
