Integration with Security System
                    I am looking into replacing a security system that is installed. The current system is HAI and was installed by another company. We may take over the system or replace in the near futrue because the client is not happy with it.
What security systems does everyone perfer to integrate with. I was thinking of Honeywell Vista 128BP or 128 FBP for one property and maybe the 250 series for another site if the additional zones will be needed.
I was also looking at Digital Monitoring Products (DMP) XR100N or XR500N control panels. This systems gives me the ability to access control on the same platform and might be easier to due a complete integration with one system vs. 2 independent systems. Has anyone integrated with DMP? If so please provide me with some feedback on the integration compared to other systems.
http://buy.dmp.com/dmp/Shop?DSP=30100&PCR=1:100:10010:10085&IID=XR100N
http://buy.dmp.com/dmp/Shop?DSP=30100&PCR=1:100:10010:10056&IID=XR500N
Thanks to all!
Thanks to all!
We use the GE. It works much like the old Destiny 6100.
Ademco is similar (or was, last I used it, in any case). They consider the chip you install to allow communications secure enough ... and you don't need a passcode at all to arm or disarm through it, so you have to secure your interface yourself.
The AMX panel can easily be made to exactly mirror the functionality of the DSC keypad and AMX does not have to store passwords or user names at all.
I second this. The Elk M1 was engineered with control system integration in mind. The Ademco Vista was engineered with dot matrix printer integration in mind. 'Nuff said. Granted the Vista is much better than it used to be, but the M1 is still the superior product, IMO.
+1. The Elk is a great product.
Ha Ha...Good one!
You can control any Ademco Vista series alarm panel using 1 relay, 2 I/O's, and some resistors. The limitations are that this will only work on a single partition and you have to dedicate a zone to it.
You will need to have a zone configured for key switch control. Once this has been configured, you can arm and disarm the system using a relay connected to the designated zone. A pulse of less than 1/2 second will arm in Away mode, a pulse for 10 seconds will arm in Stay mode, and another short pulse will disarm the system.
The 2 I/O's are used for tracking the system status. Connect them to the 8-pin trigger connector. I/O 1 will be used for Ready status and I/O 2 will be used for Arm status.
I/O status indicators:
1 (On), 2 (Off) = Disarmed & Ready
1 (Off), 2 (Off) = Disarmed & Not Ready
1 (Off), 2 (On Steady) = Armed Away
1 (Off), 2 (Slow Flash) = Armed Stay
Manual can be found here: http://www.alarmeengros.com/installation15P.pdf
Schematic is on page 2-9
I/O detail: http://www.canbroc.com/downloads/vista128_ig.pdf
Chart is on page 3-16
Touche! But if it's all you got... it's better than nothing.
