AMX Novarra
Has anyone programmed AMX Novarra keypad, I am controlling a Sharp 65inch LCD which has a command for volume VOLM(0-60). How will be the volume up and volume down incorporated with this command.
  • You will need volume up/down commands to implement this, discrete volume control programming is, as far as i know, not supported in the novara keypads.
    thanks for the reply
    so in this case I would just call a presets on volume... (eg 10%, 50%, 100%)
  • edgelitocedgelitoc Posts: 160
    novarra keypad in windows 7
    hi there, has any one tried the novarra in windows 7 does it work....
  • Jorde_VJorde_V Posts: 393
    edgelitoc wrote: »
    It doesn't. at least not on the 64-bit version. I had to use windows xp to program them.
