RS-485 cable
in AMX Hardware
Hi all,
I have a RS-485 ( A, B, GND ) interface embeded in a Lighting control.
I want to connect to NI-900 serial port.
Could somebody please let me know the correct wire cable.
Thanks in advance
Thanks in advance
With RS485 you need to be aware that A&B are sometimes referenced differently with different manufacturers, if things are not communicating, try swapping A & B over.
HTH
Example: send_command dvPelcoD,"'SET BAUD 4800,N,8,1 485 ENABLE'";
Thanks folks.
