Why does TO not work on this code?
dvTPMB_TV		= 10001:7:0  //MBed TP Plasma Vol functions
TV_MBED			= 5001:14:0  //Physical IR port for the plasma
BUTTON_EVENT[dvTPMB_TV,0]  //Typically Volume Controls
	TO[TV_MBED,BUTTON.INPUT.CHANNEL]
When this code executes, the IR is pulsed instead of continuously sent while I hold down the button.
If I change the code to a stacked button event:
BUTTON_EVENT[dvTPMB_TV,24]  //vol up
BUTTON_EVENT[dvTPMB_TV,25]  //vol dn
It works fine. Is it something to do with the wildcard?
    I would guess it's the wildcard. It must be handled runtime, or else the event tables would be enormous. So, on account of that, BUTTON.INPUT.CHANNEL probably has no meaning in a whildcard context.
    DHawthorne wrote: »
    I use BIC w/ the "0" catch all when ever I use the "0" so I can say with certainty that BIC isn't the culprit. There used to be issues with "0" and holds that seems to have been resolved so I'm thinking it must be how the "TO" is handled by the system that makes a difference when using "0".
    In TPD4 is the panel button set up as momemtary? If so that could be the problem.
    You might just do the "TO" yourself in code by issuing an ON[TP,BIC] in the push and OFF[TP,BIC] in the release. Basically this is all a "TO" is, turning some type of channel on until it's released.
    Using the 0 wildcard with a TO and BUTTON.INPUT.CHANNEL worked fine for me when I tested it.
    Joe Hebert wrote: »
    I thought it should work, I just haven't used it with "0" and generally don't use "TO" at all anymore anywhwere. Since it does work I would suspect the button is set to momemtary not channel for feedback. The panel will issue a push on a press & automatically issue a release regardless of the button still being held thereby negating the "TO".
  • ColzieColzie Posts: 470
    I'm in the habit of doing a
    push:
        if (button.input.channel)
            //  handle the button press
    when I use the [dv_TP,0] button press. I can't remember exactly why I started doing it, but obviously I must have gotten inadvertent button presses with b.i.c=0.
    Colzie wrote: »
    push:
    I know that used to cause the HOLD handler to run constantly cuz it would think button 0 was being held when nothing else was being pushed or held so it stands to reason that it would first issue a push. I don't beleive that's an issue anymore but I still prefer to run a select active or switch case on my BIC just to make sure the channel falls into a particular range.
  • the8thstthe8thst Posts: 470
    I usually do something like this:
    	define_constant
    	integer nIRchannelLimit	= 170
    	integer nIRpresetLimit	= 210
    	define_function integer isValid (integer startPoint, integer value, integer endPoint)
    		if ((value >= startPoint) && (value <= endPoint))
    			return 1
    		else
    			return 0
    	define_event
    	button_event[dvIR_TParray,0]
    		push: {
    			// TP and source tracking omitted here
    			select {
    				active (isValid(1,button.input.channel,nIRchannelLimit)): {
    					// do source IR commands here
    				active (isValid(nIRchannelLimit,button.input.channel,nIRpresetLimit)): {
    					// do source Preset commands here
    				active (1): {
    					fnMainDebug('sourceControl',__line__,"'invalid IR channel: tp[',dpstoa(button.input.device),'] chan[',itoa(button.input.channel),']'")
