Mi-series
I'm busy on a job where I've had to reprogramme a control system involving a Mi-series DAS-M0808. 7 inputs (2-8) have been used at present, and the idea was to utilize the 1st input for the new blu-ray player being installed. However, no audio gets passed through the first input for some unknown reason. The same source works on all other inputs, and the programming appears to switch to any other input but the first one. Is there record of these devices failing such that a single input would be broken? Or must it be an issue with the coding?
http://www.amx.com//techdocs/DAS.Mi.Series.OperationReferenceGuide.pdf
PDF page 83 shows the positions for operation. The device can have two tuners, and that is why there are two sections to adjust. By default, the second wll be in the OFF position.
Hope this helps!
