Doorbell Phones and Paging
Spire_Jeff
Has anyone found a product that adds doorbell phone and wholehouse paging functions to a distributed audio system? We can get the doorbell phone and paging through a panasonic phone system, but it lacks the annoying (but requested) ding-dong sound over the speakers. We can use the ELAN Z600, but it requires some work to get everything to work properly and the doorphone portion doesn't work as well as I'd like.
As I write this, another option comes to mind. Anyone know of a reliable device that will play a sound from a contact closure?
Hi Jeff,
Have you tried CFSound? I'm using this as part of a phone interface solution. It's a pretty sweet product for $120. I haven't done any long term testing with it but so far it's been working great.
CFSound will play sounds from contact closures or from simple RS-232 commands.
http://cfsound.com/index_CFSound.asp
Hope this helps.
Joe
I have also used i!-MediaPlayer to play sounds throughout a house on contact and telephone events, but I was never really happy with it. For one thing, you need to dedicate a computer to your system (which is fine if it pre-existed, but hard to justify buying for that purpose); for another, i!-MediaPlayer is just a little flaky. But that's another option.
Joe
http://www.nilesaudio.com/images/PDF/DBI-1-Cutsheet.pdf
It has multiple chimes and two contact closures for Door 1 and Door 2. The doors can have different sounding chimes as well.
The cool part about this is that it outputs a 12v trigger while it is playing the chime and then the trigger goes low when the chime is finished.
It is a cool inexpensive piece.
