IR Edit on WIn 7
People, how to install IREdit on Win7 ? It report me that I do not have .NET installed, and I have newest version on PC.
Any idea ?
    You will have to install .NET . Go to the Microsoft site and install the .NET Framework.
  • VladaPUBVladaPUB Posts: 139
    I have instalated .net !
    Problem was with support files. Now it works ok !
  • How did you get this to work? I'm having the same issue.
    Install .Net Download and install support files, and run it. This should resolve problem.
  • Turn on .net in windows 7
    type in serch programs and file box as follows
    Turn Windows features on or off
    then u will guide in to new window named windows features
    check mark microsoft .NET trame work..
    then ok enjoy ur work in windows 7
    make sure you installed IR edit system files befor you hit ir edit setup file
  • alanhalanh Posts: 30
    i ran the iredit setup file as Administrator under the right mouse click and this solved my problems with windows 7, another solution is to right click the IRedit program and pick properties and then compatibility and run the program in compatibility mode Windows Xpservice pack 2 from the drop down window.
    hope it helps
  • Install in XP SP3 compatible mode and be sure you have installed the system files.
    http://amx.com/techcenter/downloadConfirm.asp?fn=/assets/applicationFiles/IREditSystemFiles.exe
  • a more global solution
    Hi,
    since win7x64 makes more problems with older software I decided to install VirtualBox, running a virtual XP SP3 in it. Works perfect, not only for the IR-learner.
    Alexander
