9000i autoswitch from wired to wireless?
in AMX Hardware
We're installing a couple of the 9000i touch panels and everything seems to work ok both wired and wireless. Problem is that when they are removed from the dock station (where they are wired/ethernet) they don't automatically reconnect to the master via wireless though the TPs indicate that they are, in fact, connected to the access point. Anything that affects the wireless connection, like touching anything to do with WEP or re-selecting the access point from the site survey, or (of course) a reboot or shutdown/restart and the wireless connection to the master will be remade just fine. But, just removing from the dock station doesn't do it.
So, should it auto connect to the master via WiFi when removed from the dock station?
We're using the Netgear blue box Waps (WG102) which have given us the best success of all the waps, so I don't think that's it, though it could be. Also there is newer firmware (which will be loaded when we go out there next week. Would have done it today but we didn't have internet access). Is this one of the issues that was addressed with the latest firmware or is it just the way it is? Is it necessary to turn on roaming? Hadn't thought of that before.
Looks like you have the "force undock" issue below. (from newest 9000i firmware notes)
Apparently, there is supposed to be some way for this to work, but it doesn't for us. Perhaps the newer firmware will fix this. Sure do hope so.
In sensitive commercial installs or where WIFI is severely constricted for security or other reasons, it could make sense to shift to wired where possible. They may be more willing to tolerate the behavior that results.
The only benefit I could ever see was if you were sending component video to the panel when its docked but I don't think that's even possible.
I've only installed 2 of these panels but in this installation both are docked but only one is dock with wired ethernet. These panels almost never leave the dock and the only time that I know of that my client's wife undocked to use she complained about the weight. So in this instance they will most likely stay docked 99% of the time and when they do remove them from the docks they will likely carry out to the patio (if evening) so I guess it depends on the install whether to leave them wi-fi only or both (They have R4's or 5200's for all TV location). If it stays in the dock why congest an access point that's runs at 1/2 duplex. Not that there's much else on the wireless network.
I guess I'll to play with it and see how bad it really is.
The 9000 has no live video. Just IP video.
You've got it right. I loaded the latest master and TP firmware and the autoswap works fine.
Thanks for the advice/thoughts.
Closing connection to due to failed address swap
But usually it was just these:
CICSPTCP Rx connection to 192.168.1.51 has been closed locally or by peer
ICSPTCP12::CloseSocket: Closing Socket
I'll be calling tech support when they open but thought I'd see if anyone else has had this issue.
