Power Assign only the Port?
Is it possible to Power Assign only the port on a page of buttons? I have a single Sat DVR page, but 5 identical DVRs, and I have copied and pasted the page, and renamed the copies to follow the naming convention of the DVRs. I want to just change the port # on each page. For coding, I have created a panel port (10001:1:0, 10001:2:0, etc) for each of these DVRs, which is why I want different port numbers. The channel numbers are already assigned. Thanks!
I would much prefer just having one TP page for all the instances then have one for each instance. It's just a matter of tracking which device you're controlling and routing to the appropriate device. Of course if you're using one of those existng AMX module that requires a UI instance for each UI and each device then it's a lot of work to re-write it.
