$P & other TP text field Commands
Where can I find a list of the available commands that we can insert into the text field like $P? I swear I had a list once but god knows where I put it and where I originally found it in the first place.
I searched $P in the TPDesign Help and found the following:
Formatting Codes
Formatting codes can be used in the Text for Bargraph and Multi-State Bargraph buttons. The following formatting codes will be replaced with the identified values:
$P - level percentage
$V - raw level value
$L - range low
$H - range high
$A - adjusted level value (raw level value - range low)
$R - range (range high - range low)
$$ - $ character
I think almost all of this sort of stuff is included in the reference manual for each TP. For example, the MVP-9000iOperationReferenceGuide.pdf includes information about "Text Formatting" in appendix A, including the $P.
Muchas Gracias Senor!
