Cafe Duet and Eclipse
                    Cafe Duet is built on the Eclipse platform, but it is customized for the Duet and Netlinx specific requirements.  For anyone using Duet that also programs generic Java applications in Eclipse, have you found a way to use a single standard Eclipse IDE that can correctly edit/compile Duet modules using J2ME (1.4, I think) and current Java applications using the latest 1.6 release?
Currently, I just run two copies, standard Duet for Duet modules and Eclipse for everything else. I haven't found the magic trick to combine the two into one.
Just curious if anyone else has.
Thanks.
Sheldon Samuels
Thanks.
Sheldon Samuels
Have you or anyone been successful in running Duet on a full Eclipse environment?
