TPDesign can't transfer file to R4 remote NAK code 0x0012
When you receive the error message:
Error performing action Create Remote Panel Directories:
Device returned file transfer NAK code 0x0012:
Unknown error; please contact technical support
This message happens when the R4 remote is not docked in its charging cradle.
Dock the R4 in the charging cradle and transfer the file again should work.
I got stuck with this for a few hours so I posted the cause.
AMX should make the error code more descriptive please.
Please see page 31 of the "Operation/Reference Guide - MIO-R4" PDF:
Meant to be read or not, that is the most silly description of an error I've ever seen. If you just started out it would be something you don't know, but if it just said: "Please place the R4 in it's cradle before filetransfer" or "The R4 needs to be charging for filetransfers".
Anyone would know. Descriptive errors are considered good coding practise.. And unless AMX is going to come up with a proper error code knowledge base, should be required.
This is not a defense. Only more background that might just give a ray of light on the thankless job that is software.
RTFM.
