Xbmc
sickkick
I am trying to convert this ******** module to AMX. But I can't figure it out. The packet that has to be sent is in bytes.
SIMPL+ Module Information
(Fill in comments below)
Dealer Name:
System Name:
System Number:
Programmer: Neil Carthy (arduino@scpgwiki.com)
Comments:
In order for this module to work you must switch on EventServer:
Set "Allow Programs on this system to control XMBC" to ON, and
"Allow Programs on other systems to control XMBC" to ON.
In writing this module I drew heavily on the C# module written by
Peter Tribe aka EqUiNox (TeamBlackbolt).
***** License *****
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
/////////////////////Compiler Directives
#SYMBOL_NAME "XBMC-ES"
#CATEGORY "41" // Remote System Interface
#HINT "Control XBMC using EventServer API"
#PRINT_TO_TRACE
#ENABLE_DYNAMIC
#DEFAULT_VOLATILE
#ENABLE_STACK_CHECKING
#ENABLE_TRACE
#OUTPUT_SHIFT 2 // Shift the outputs down 2 lines on the SIMPL window
/***** DEFINE NEW CONSTANTS *******/
//#DEFINE_CONSTANT DEBUG 1
#DEFINE_CONSTANT GATHER_TIMEOUT 15 // Timeout period to wait for response in 1/100th of second
#DEFINE_CONSTANT MAX_PACKET_SIZE 1024
#DEFINE_CONSTANT HEADER_SIZE 32
#DEFINE_CONSTANT MAX_PAYLOAD_SIZE 992 // Max payload in any one packet, equals (BUFFER_SIZE - HEADER_SIZE)
#DEFINE_CONSTANT MAJOR_VERSION 2
#DEFINE_CONSTANT MINOR_VERSION 0
#DEFINE_CONSTANT ICON_NONE 0
#DEFINE_CONSTANT ICON_JPEG 1 // Not Used
#DEFINE_CONSTANT ICON_PNG 2 // Not Used
#DEFINE_CONSTANT ICON_GIF 3 // Not Used
#DEFINE_CONSTANT BUTTON_USE_NAME 1
#DEFINE_CONSTANT BTN_DOWN 2
#DEFINE_CONSTANT BTN_UP 4
#DEFINE_CONSTANT BUTTON_USE_AMOUNT 8
#DEFINE_CONSTANT BUTTON_QUEUE 16
#DEFINE_CONSTANT BUTTON_NO_REPEAT 32
#DEFINE_CONSTANT BTN_VKEY 64
#DEFINE_CONSTANT BTN_AXIS 128
#DEFINE_CONSTANT MS_ABSOLUTE 1 // Mouse flags type
#DEFINE_CONSTANT LOGDEBUG 0
#DEFINE_CONSTANT LOGINFO 1
#DEFINE_CONSTANT LOGNOTICE 2
#DEFINE_CONSTANT LOGWARNING 3
#DEFINE_CONSTANT LOGERROR 4
#DEFINE_CONSTANT LOGSEVERE 5
#DEFINE_CONSTANT LOGFATAL 6
#DEFINE_CONSTANT LOGNONE 7
#DEFINE_CONSTANT ACTION_EXECBUILTIN 1
#DEFINE_CONSTANT ACTION_BUTTON 2
// Packet Type constants
#DEFINE_CONSTANT PT_HELO 1
#DEFINE_CONSTANT PT_BYE 2
#DEFINE_CONSTANT PT_BUTTON 3
#DEFINE_CONSTANT PT_MOUSE 4
#DEFINE_CONSTANT PT_PING 5
#DEFINE_CONSTANT PT_BROADCAST 6 //Currently not implemented
#DEFINE_CONSTANT PT_NOTIFICATION 7
#DEFINE_CONSTANT PT_BLOB 8
#DEFINE_CONSTANT PT_LOG 9
#DEFINE_CONSTANT PT_ACTION 10
#DEFINE_CONSTANT PT_DEBUG 255 //Currently not implemented
#DEFINE_CONSTANT BUTTON_UP 1
#DEFINE_CONSTANT BUTTON_DOWN 2
#DEFINE_CONSTANT BTN_LEFT 3
#DEFINE_CONSTANT BTN_RIGHT 4
#DEFINE_CONSTANT BTN_SELECT 5
#DEFINE_CONSTANT BTN_STOP 6
#DEFINE_CONSTANT BTN_PLAY 7
#DEFINE_CONSTANT BTN_PAUSE 8
#DEFINE_CONSTANT BTN_TITLE 9
#DEFINE_CONSTANT BTN_MENU 10
#DEFINE_CONSTANT BTN_INFO 11
#DEFINE_CONSTANT BTN_BACK 12
#DEFINE_CONSTANT BTN_DISPLAY 13
#DEFINE_CONSTANT BTN_POWER 14
#DEFINE_CONSTANT BTN_SKIPMINUS 15
#DEFINE_CONSTANT BTN_SKIPPLUS 16
#DEFINE_CONSTANT BTN_FORWARD 17
#DEFINE_CONSTANT BTN_MYVIDEO 18
#DEFINE_CONSTANT BTN_MYMUSIC 19
#DEFINE_CONSTANT BTN_MYPICS 20
#DEFINE_CONSTANT BTN_MYTV 21
#DEFINE_CONSTANT BTN_REVERSE 22
#DEFINE_CONSTANT BTN_ZERO 23
#DEFINE_CONSTANT BTN_ONE 24
#DEFINE_CONSTANT BTN_TWO 25
#DEFINE_CONSTANT BTN_THREE 26
#DEFINE_CONSTANT BTN_FOUR 27
#DEFINE_CONSTANT BTN_FIVE 28
#DEFINE_CONSTANT BTN_SIX 29
#DEFINE_CONSTANT BTN_SEVEN 30
#DEFINE_CONSTANT BTN_EIGHT 31
#DEFINE_CONSTANT BTN_NINE 32
#DEFINE_CONSTANT BTN_RECORD 33
#DEFINE_CONSTANT BTN_START 34
#DEFINE_CONSTANT BTN_VOLUMEPLUS 35
#DEFINE_CONSTANT BTN_VOLUMEMINUS 36
#DEFINE_CONSTANT BTN_CHANNELPLUS 37
#DEFINE_CONSTANT BTN_CHANNELMINUS 38
#DEFINE_CONSTANT BTN_PAGEPLUS 39
#DEFINE_CONSTANT BTN_MUTE 40
#DEFINE_CONSTANT BTN_RECORDED_TV 41
#DEFINE_CONSTANT BTN_GUIDE 42
#DEFINE_CONSTANT BTN_LIVE_TV 43
#DEFINE_CONSTANT BTN_STAR 44
#DEFINE_CONSTANT BTN_HASH 45
#DEFINE_CONSTANT BTN_CLEAR 46
#DEFINE_CONSTANT BTN_ENTER 47
#DEFINE_CONSTANT BTN_XBOX 48
#DEFINE_CONSTANT BTN_PAGEMINUS 49
#DEFINE_CONSTANT ACTN_REBOOT 101
#DEFINE_CONSTANT ACTN_SHUTDOWN 102
#DEFINE_CONSTANT ACTN_POWERDOWN 103
#DEFINE_CONSTANT ACTN_QUIT 104
#DEFINE_CONSTANT ACTN_HIBERNATE 105
#DEFINE_CONSTANT ACTN_SUSPEND 106
#DEFINE_CONSTANT ACTN_RESTARTAPP 107
#DEFINE_CONSTANT ACTN_MINIMIZE 108
#DEFINE_CONSTANT ACTN_CREDITS 109
#DEFINE_CONSTANT ACTN_MASTERMODE 110
#DEFINE_CONSTANT ACTN_TAKESCREENSHOT 111
#DEFINE_CONSTANT ACTN_RELOADSKIN 112
#DEFINE_CONSTANT ACTN_PLAYLISTCLEAR 113
#DEFINE_CONSTANT ACTN_EJECTTRAY 114
#DEFINE_CONSTANT ACTN_PLAYDVD 115
#DEFINE_CONSTANT ACTN_RIPCD 116
#DEFINE_CONSTANT ACTN_MUTE 117
#DEFINE_CONSTANT ACTN_SYSTEMLOGOFF 118
#DEFINE_CONSTANT ACTN_UPDATEVIDEODB 119
#DEFINE_CONSTANT ACTN_UPDATEMUSICDB 120
#DEFINE_CONSTANT ACTN_CLEANVIDEODB 121
#DEFINE_CONSTANT ACTN_CLEANMUSICDB 122
#DEFINE_CONSTANT ACTN_PAGEDOWN 123
#DEFINE_CONSTANT ACTN_PAGEUP 124
#DEFINE_CONSTANT ACTION_NEXT_LETTER 125
#DEFINE_CONSTANT ACTION_PREV_LETTER 126
#DEFINE_CONSTANT ACTION_JUMP_SMS2 127
#DEFINE_CONSTANT ACTION_JUMP_SMS3 128
#DEFINE_CONSTANT ACTION_JUMP_SMS4 129
#DEFINE_CONSTANT ACTION_JUMP_SMS5 130
#DEFINE_CONSTANT ACTION_JUMP_SMS6 131
#DEFINE_CONSTANT ACTION_JUMP_SMS7 132
#DEFINE_CONSTANT ACTION_JUMP_SMS8 133
#DEFINE_CONSTANT ACTION_JUMP_SMS9 134
#DEFINE_CONSTANT ACTION_SHOW_SUBTITLES 135
#DEFINE_CONSTANT ACTION_NEXT_SUBTITLE 136
#DEFINE_CONSTANT ACTION_SUBTITLE_DELAY_MIN 137
#DEFINE_CONSTANT ACTION_SUBTITLE_DELAY 138
#DEFINE_CONSTANT ACTION_SUBTITLE_DELAY_PLUS 139
#DEFINE_CONSTANT ACTION_SHOW_GUI 140
#DEFINE_CONSTANT ACTION_TOGGLE_FULLSCREEN 141
#DEFINE_CONSTANT ACTION_FILTER_CLEAR 142
#DEFINE_CONSTANT ACTION_FILTER_SMS2 143
#DEFINE_CONSTANT ACTION_FILTER_SMS3 144
#DEFINE_CONSTANT ACTION_FILTER_SMS4 145
#DEFINE_CONSTANT ACTION_FILTER_SMS5 146
#DEFINE_CONSTANT ACTION_FILTER_SMS6 147
#DEFINE_CONSTANT ACTION_FILTER_SMS7 148
#DEFINE_CONSTANT ACTION_FILTER_SMS8 149
#DEFINE_CONSTANT ACTION_FILTER_SMS9 150
#DEFINE_CONSTANT ACTION_FIRST_PAGE 151
#DEFINE_CONSTANT ACTION_LAST_PAGE 152
#DEFINE_CONSTANT ACTION_AUDIO_DELAY_MIN 153
#DEFINE_CONSTANT ACTION_AUDIO_DELAY 154
#DEFINE_CONSTANT ACTION_AUDIO_DELAY_PLUS 155
#DEFINE_CONSTANT ACTION_AUDIO_NEXT_LANGUAGE 156
#DEFINE_CONSTANT ACTION_TOGGLE_WATCHED 157
#DEFINE_CONSTANT ACTION_SHOW_CODEC 158
#DEFINE_CONSTANT ACTION_TAKE_SCREENSHOT 159
#DEFINE_CONSTANT ACTION_CONTEXT_MENU 160
#DEFINE_CONSTANT ACTION_SHOW_OSD 161
#DEFINE_CONSTANT ACTION_SHOW_ASPECT_RATIO 162
DIGITAL, ANALOG and SERIAL INPUTS and OUTPUTS
(Uncomment and declare inputs and outputs as needed)
DIGITAL_INPUT _SKIP_, _SKIP_, Connect,_SKIP_;
DIGITAL_INPUT Up, Down, Lt, Rt, _SKIP_;
// builin functions that require feedback
DIGITAL_INPUT Repeat, Shuffle, _SKIP_;
ANALOG_INPUT Command;
ANALOG_INPUT WindowName#; // Activate this window (Delta Window ID) See http://wiki.xbmc.org/index.php?title=Window_IDs
STRING_INPUT WindowName$[100];
STRING_INPUT _SKIP_, XBMC_IPAddr$[16], //the ip of the XBMC server.
_SKIP_;
BUFFER_INPUT LogMessage$[500];
BUFFER_INPUT Notification$[500];
STRING_OUTPUT RepeatStatus$, // 'Repeat', 'RepeatOne' or 'RepeatAll' or ''
ShuffleStatus$; // 'Shuffle' or ''
///////////////////////////// Parameters
INTEGER_PARAMETER EventServer_Port#; //the port that the XBMC sends broadcast packets from
#BEGIN_PARAMETER_PROPERTIES EventServer_Port#
propValidUnits = unitDecimal;
propDefaultValue = 9777d;
propShortDescription = "The port that the XBMC listens on for EventServer packets.";
#END_PARAMETER_PROPERTIES
/////////////////////////// Global variables
NONVOLATILE INTEGER RepeatCounter, ShuffleCounter; //Used to track repeat and shuffle status
/////////////////////////// Sockets
UDP_SOCKET EventServerUdp[MAX_PACKET_SIZE]; // EventServer UDP socket
Global Variables
(Uncomment and declare global variables as needed)
Note: Be sure to initialize all declared STRING variables as needed
For example, in Function Main: myString = "";
INTEGER UniqueToken; // Used by xbmc to identify each client, set to a random number
STRING Header$[HEADER_SIZE]; // The header that comes before the Payload of each packet
STRING Payload$[MAX_PACKET_SIZE]; // The payload buffer that is transferred to XBMC
INTEGER PayloadLength; // The actual length of the payload. (Payload$ is padded with zeros)
Functions
Note: Functions must be physically placed before the location in
the code that calls them.
// Insert Header details into Header$
FUNCTION GenerateHeader(INTEGER PacketType)
STRING HeaderStart$[6];
MAKESTRING (HeaderStart$, "XBMC%s%s", Chr(MAJOR_VERSION), Chr(MINOR_VERSION));
MAKESTRING ( Header$, "%s%s%s%s%s%s%s%s%s%s%s"
,HeaderStart$
,Chr(High(PacketType))
,Chr(Low(PacketType))
,"\x00\x00\x00\x01\x00\x00\x00\x01" // Only works for a single packet
,Chr(High(PayloadLength))
,Chr(Low(PayloadLength))
,Chr(High(HighWord(UniqueToken)))
,Chr(Low(HighWord(UniqueToken)))
,Chr(High(LowWord(UniqueToken)))
,Chr(Low(LowWord(UniqueToken)))
,"\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00" //Padding
FUNCTION Send(INTEGER PacketType)
STRING Packet$[MAX_PACKET_SIZE];
CALL GenerateHeader(PacketType);
IF (PayloadLength = 0)
MAKESTRING(Packet$, "%s", Header$);
ELSE
MAKESTRING(Packet$, "%s%s", Header$, LEFT(Payload$, PayloadLength));
IF (SOCKETSEND(EventServerUdp, Packet$) < 0)
PRINT ("Connect: %d", Connect);
PRINT ("IP address: %s", XBMC_IPAddr$);
/* SendHelo - */
/* Payload format: */
/* %s - device name (max 128 chars) */
/* %c - icontype ( 0=>NOICON, 1=>JPEG , 2=>PNG , 3=>GIF ) */
/* %s - my port ( 0=>not listening ) */
/* %d - reserved1 ( 0 ) */
/* %d - reserved2 ( 0 ) */
/* XX - imagedata ( can span multiple packets ) */
FUNCTION SendHelo(STRING DeviceName$)
PayloadLength = LEN(DeviceName$) + 12;
MAKESTRING(Payload$, "%s\x00%s\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00"
,DeviceName$
,Chr(ICON_NONE) //Not using Icons in this version of XBMC-ES
CALL Send(PT_HELO);
/* SendBye - No payload */
/* A BYE packet terminates the connection to XBMC. */
FUNCTION SendBye()
PayloadLength = 0;
CALL Send(PT_BYE);
/* SendPing - No payload */
/* A PING packet tells XBMC that the client is still alive. All valid */
/* packets act as ping (not just this one). A client needs to ping */
/* XBMC at least once in 60 seconds or it will time out. */
FUNCTION SendPing()
PayloadLength = 0;
CALL Send(PT_PING);
/* SendLog - Payload format */
/* %c - log type */
/* %s - message */
FUNCTION SendLog(INTEGER LogLevel, string Message$)
PayloadLength = LEN(Message$) + 2;
MAKESTRING(Payload$, "%s%s\x00"
,Chr(LogLevel)
,Message$
CALL Send(PT_LOG);
/* SendNotification - Payload format */
/* %s - caption */
/* %s - message */
/* %d - reserved ( 0 ) */
FUNCTION SendNotification(string Caption$, string Message$)
PayloadLength = LEN(Caption$) + LEN(Message$) + 7;
MAKESTRING(Payload$, "%s\x00%s\x00%s\x00\x00\x00\x00"
,Caption$
,Message$
CALL Send(PT_NOTIFICATION);
/* SendButton - Payload format */
/* %i - button code */
/* %i - flags 0x01 => use button map/name instead of code */
/* 0x02 => btn down */
/* 0x04 => btn up */
/* 0x08 => use amount */
/* 0x10 => queue event */
/* 0x20 => do not repeat */
/* 0x40 => virtual key */
/* 0x80 => axis key */
/* %i - amount ( 0 => 65k maps to -1 => 1 ) */
/* %s - device map (case sensitive and required if flags & 0x01) */
/* "KB" - Standard keyboard map */
/* "XG" - Xbox Gamepad */
/* "R1" - Xbox Remote */
/* "R2" - Xbox Universal Remote */
/* "LI:devicename" - valid LIRC device map where 'devicename' */
/* is the actual name of the LIRC device */
/* "JS<num>:joyname" - valid Joystick device map where */
/* 'joyname' is the name specified in */
/* the keymap. JS only supports button code */
/* and not button name currently (!0x01). */
/* %s - button name (required if flags & 0x01) */
FUNCTION SendButton(string Button$, INTEGER ButtonCode, string DeviceMap$, INTEGER Flags, INTEGER Amount)
PayloadLength = LEN(Button$) + LEN(DeviceMap$) + 8;
IF (LEN(Button$) > 0)
IF ((Flags & BUTTON_USE_NAME) = 0)
Flags = Flags | BUTTON_USE_NAME;
ButtonCode = 0;
IF (Amount > 0)
IF ((Flags & BUTTON_USE_AMOUNT) = 0)
Flags = Flags | BUTTON_USE_AMOUNT;
IF (!(Flags & BTN_DOWN || Flags & BTN_UP ))
Flags = Flags | BTN_DOWN;
MAKESTRING(Payload$, "%s%s%s%s%s%s%s\x00%s\x00"
,Chr(High(ButtonCode))
,Chr(Low(ButtonCode))
,Chr(High(Flags))
,Chr(Low(Flags))
,Chr(High(Amount))
,Chr(Low(Amount))
,DeviceMap$
,Button$
CALL Send(PT_BUTTON);
/* SendMouse - Payload format */
/* %c - flags */
/* - 0x01 absolute position */
/* %i - mousex (0-65535 => maps to screen width) */
/* %i - mousey (0-65535 => maps to screen height) */
FUNCTION SendMouse(INTEGER X, INTEGER Y)
PayloadLength = 9;
MAKESTRING(Payload$, "%s%s%s%s%s\x00\x00\x00\x00"
,Chr(MS_ABSOLUTE)
,Chr(High(X))
,Chr(Low(X))
,Chr(High(Y))
,Chr(Low(Y))
CALL Send(PT_MOUSE);
/* SendAction - Payload format */
/* %c - action type */
/* %s - action message */
FUNCTION SendAction(INTEGER Action, string Message$)
,Chr(Action)
,Message$
CALL Send(PT_ACTION);
Raise Button-Down and Button-Up events
FUNCTION ProcessButton(STRING button_name)
CALL SendButton(button_name,0,"R1",BTN_DOWN | BUTTON_NO_REPEAT, 0);
Delay(5);
CALL SendButton(button_name,0,"R1",BTN_UP | BUTTON_NO_REPEAT, 0);
Event Handlers
(Uncomment and declare additional event handlers as needed)
PUSH Connect
INTEGER LocalStatus;
LocalStatus = SocketUDP_Enable(EventServerUdp, XBMC_IPAddr$, EventServer_Port#);
IF (LocalStatus != 0)
#IF_DEFINED DEBUG PRINT("UDP Error: %s:%d", XBMC_IPAddr$, EventServer_Port#); #ENDIF
GenerateUserError( "(%s) %s", GetSymbolInstanceName( ), "Unable to enable EventServer Udp socket." );
CALL SendHelo("******** System");
WHILE (Connect)
// 30-sec wait
DELAY(3000);
// Ensure the release event is captured
PROCESSLOGIC();
// Check again just in case
IF (Connect)
CALL SendPing();
RELEASE Connect
CALL SendLog(LOGNOTICE, "ES: ******** System closed connection.");
Delay(50);
CALL SendBye();
LocalStatus = SocketUDP_Disable(EventServerUdp);
GenerateUserError( "(%s) %s", GetSymbolInstanceName( ), "Unable to DISable EventServer Udp socket." );
/* Up/Down/Left/Right are special cases... repeat is allowed */
PUSH Up
// Keyboard Button names are CButtonTranslator::TranslateKeyboardString
// in XBMC source code
CALL SendButton("up",0,"R1",BTN_DOWN, 0);
PUSH Down
CALL SendButton("down",0,"R1",BTN_DOWN, 0);
PUSH Lt
CALL SendButton("left",0,"R1",BTN_DOWN, 0);
PUSH Rt
CALL SendButton("right",0,"R1",BTN_DOWN, 0);
RELEASE Up
CALL SendButton("up",0,"R1",BTN_UP, 0);
RELEASE Down
CALL SendButton("down",0,"R1",BTN_UP, 0);
RELEASE Lt
CALL SendButton("left",0,"R1",BTN_UP, 0);
RELEASE Rt
CALL SendButton("right",0,"R1",BTN_UP, 0);
CHANGE Command
Switch (Command)
Case (BUTTON_UP) : { ProcessButton("up"); }
Case (BUTTON_DOWN) : { ProcessButton("down"); }
Case (BTN_LEFT) : { ProcessButton("left"); }
Case (BTN_RIGHT) : { ProcessButton("right"); }
Case (BTN_SELECT) : { ProcessButton("select");}
Case (BTN_STOP) : { ProcessButton("stop"); }
Case (BTN_PLAY) : { ProcessButton("play"); }
Case (BTN_PAUSE) : { ProcessButton("pause"); }
Case (BTN_RECORD) : { ProcessButton("record"); }
Case (BTN_START) : { ProcessButton("start"); }
Case (BTN_TITLE) : { ProcessButton("title"); }
Case (BTN_MENU) : { ProcessButton("menu"); }
Case (BTN_INFO) : { ProcessButton("info"); }
Case (BTN_BACK) : { ProcessButton("back"); }
Case (BTN_DISPLAY) : { ProcessButton("display");}
Case (BTN_POWER) : { ProcessButton("power"); }
Case (BTN_SKIPMINUS) : { ProcessButton("skipminus");}
Case (BTN_SKIPPLUS) : { ProcessButton("skipplus");}
Case (BTN_FORWARD) : { ProcessButton("forward");}
Case (BTN_REVERSE) : { ProcessButton("reverse");}
Case (BTN_MYVIDEO) : { ProcessButton("myvideo");}
Case (BTN_MYMUSIC) : { ProcessButton("mymusic");}
Case (BTN_MYPICS) : { ProcessButton("mypictures");}
Case (BTN_MYTV) : { ProcessButton("mytv");}
Case (BTN_ZERO) : { ProcessButton("zero"); }
Case (BTN_ONE) : { ProcessButton("one"); }
Case (BTN_TWO) : { ProcessButton("two");}
Case (BTN_THREE) : { ProcessButton("three");}
Case (BTN_FOUR) : { ProcessButton("four");}
Case (BTN_FIVE) : { ProcessButton("five");}
Case (BTN_SIX) : { ProcessButton("six");}
Case (BTN_SEVEN) : { ProcessButton("seven");}
Case (BTN_EIGHT) : { ProcessButton("eight");}
Case (BTN_NINE) : { ProcessButton("nine");}
Case (BTN_VOLUMEPLUS) : { ProcessButton("volumeplus");}
Case (BTN_VOLUMEMINUS) : { ProcessButton("volumeminus");}
Case (BTN_MUTE) : { ProcessButton("mute");}
Case (BTN_CHANNELPLUS) : { ProcessButton("channelplus");}
Case (BTN_CHANNELMINUS) : { ProcessButton("channelminus");}
Case (BTN_PAGEPLUS) : { ProcessButton("pageplus");}
Case (BTN_PAGEMINUS) : { ProcessButton("pageminus");}
Case (BTN_RECORDED_TV) : { ProcessButton("recordedtv");}
Case (BTN_GUIDE) : { ProcessButton("guide"); }
Case (BTN_LIVE_TV) : { ProcessButton("livetv");}
Case (BTN_STAR) : { ProcessButton("star"); }
Case (BTN_HASH) : { ProcessButton("hash"); }
Case (BTN_CLEAR) : { ProcessButton("clear"); }
Case (BTN_ENTER) : { ProcessButton("enter"); }
Case (BTN_XBOX) : { ProcessButton("xbox"); }
Case (ACTN_REBOOT) : { SendAction(ACTION_EXECBUILTIN, "Reboot" ); }
Case (ACTN_SHUTDOWN) : { SendAction(ACTION_EXECBUILTIN, "ShutDown" ); }
Case (ACTN_POWERDOWN) : { SendAction(ACTION_EXECBUILTIN, "Powerdown"); }
Case (ACTN_QUIT) : { SendAction(ACTION_EXECBUILTIN, "Quit"); }
Case (ACTN_HIBERNATE) : { SendAction(ACTION_EXECBUILTIN, "Hibernate"); }
Case (ACTN_SUSPEND) : { SendAction(ACTION_EXECBUILTIN, "Suspend"); }
Case (ACTN_RESTARTAPP) : { SendAction(ACTION_EXECBUILTIN, "RestartApp"); }
Case (ACTN_SYSTEMLOGOFF) : { SendAction(ACTION_EXECBUILTIN, "System.LogOff"); }
Case (ACTN_CREDITS) : { SendAction(ACTION_EXECBUILTIN, "Credits"); }
Case (ACTN_MASTERMODE) : { SendAction(ACTION_EXECBUILTIN, "Mastermode"); }
Case (ACTN_TAKESCREENSHOT) : { SendAction(ACTION_EXECBUILTIN, "TakeScreenshot"); }
Case (ACTN_RELOADSKIN) : { SendAction(ACTION_EXECBUILTIN, "ReloadSkin()"); }
Case (ACTN_MUTE) : { SendAction(ACTION_EXECBUILTIN, "Mute"); }
Case (ACTN_PLAYLISTCLEAR) : { SendAction(ACTION_EXECBUILTIN, "Playlist.Clear"); }
Case (ACTN_EJECTTRAY) : { SendAction(ACTION_EXECBUILTIN, "EjectTray()"); }
Case (ACTN_PLAYDVD) : { SendAction(ACTION_EXECBUILTIN, "PlayDVD"); }
Case (ACTN_RIPCD) : { SendAction(ACTION_EXECBUILTIN, "RipCD"); }
Case (ACTN_UPDATEVIDEODB) : { SendAction(ACTION_EXECBUILTIN, "UpdateLibrary(video)"); }
Case (ACTN_UPDATEMUSICDB) : { SendAction(ACTION_EXECBUILTIN, "UpdateLibrary(music)"); }
Case (ACTN_CLEANVIDEODB) : { SendAction(ACTION_EXECBUILTIN, "CleanLibrary(video)"); }
Case (ACTN_CLEANMUSICDB) : { SendAction(ACTION_EXECBUILTIN, "CleanLibrary(music)"); }
Case (ACTN_PAGEDOWN) : { SendAction(ACTION_EXECBUILTIN, "PageDown"); }
Case (ACTN_PAGEUP) : { SendAction(ACTION_EXECBUILTIN, "PageUp"); }
Case (ACTION_FIRST_PAGE) : { SendAction(ACTION_BUTTON, "firstpage"); }
Case (ACTION_LAST_PAGE) : { SendAction(ACTION_BUTTON, "lastpage"); }
Case (ACTION_SHOW_GUI) : { SendAction(ACTION_BUTTON, "fullscreen"); }
Case (ACTION_TOGGLE_FULLSCREEN) : { SendAction(ACTION_BUTTON, "togglefullscreen"); }
Case (ACTN_MINIMIZE) : { SendAction(ACTION_EXECBUILTIN, "Minimize"); }
Case (ACTION_NEXT_LETTER) : { SendAction(ACTION_BUTTON, "nextletter"); }
Case (ACTION_PREV_LETTER) : { SendAction(ACTION_BUTTON, "prevletter"); }
Case (ACTION_JUMP_SMS2) : { SendAction(ACTION_BUTTON, "jumpsms2"); }
Case (ACTION_JUMP_SMS3) : { SendAction(ACTION_BUTTON, "jumpsms3"); }
Case (ACTION_JUMP_SMS4) : { SendAction(ACTION_BUTTON, "jumpsms4"); }
Case (ACTION_JUMP_SMS5) : { SendAction(ACTION_BUTTON, "jumpsms5"); }
Case (ACTION_JUMP_SMS6) : { SendAction(ACTION_BUTTON, "jumpsms6"); }
Case (ACTION_JUMP_SMS7) : { SendAction(ACTION_BUTTON, "jumpsms7"); }
Case (ACTION_JUMP_SMS8) : { SendAction(ACTION_BUTTON, "jumpsms8"); }
Case (ACTION_JUMP_SMS9) : { SendAction(ACTION_BUTTON, "jumpsms9"); }
Case (ACTION_FILTER_CLEAR) : { SendAction(ACTION_BUTTON, "filterclear"); }
Case (ACTION_FILTER_SMS2) : { SendAction(ACTION_BUTTON, "filtersms2"); }
Case (ACTION_FILTER_SMS3) : { SendAction(ACTION_BUTTON, "filtersms3"); }
Case (ACTION_FILTER_SMS4) : { SendAction(ACTION_BUTTON, "filtersms4"); }
Case (ACTION_FILTER_SMS5) : { SendAction(ACTION_BUTTON, "filtersms5"); }
Case (ACTION_FILTER_SMS6) : { SendAction(ACTION_BUTTON, "filtersms6"); }
Case (ACTION_FILTER_SMS7) : { SendAction(ACTION_BUTTON, "filtersms7"); }
Case (ACTION_FILTER_SMS8) : { SendAction(ACTION_BUTTON, "filtersms8"); }
Case (ACTION_FILTER_SMS9) : { SendAction(ACTION_BUTTON, "filtersms9"); }
Case (ACTION_SHOW_SUBTITLES) : { SendAction(ACTION_BUTTON, "showsubtitles"); }
Case (ACTION_NEXT_SUBTITLE) : { SendAction(ACTION_BUTTON, "nextsubtitle"); }
Case (ACTION_SUBTITLE_DELAY_MIN) : { SendAction(ACTION_BUTTON, "subtitledelayminus"); }
Case (ACTION_SUBTITLE_DELAY) : { SendAction(ACTION_BUTTON, "subtitledelay"); }
Case (ACTION_SUBTITLE_DELAY_PLUS) : { SendAction(ACTION_BUTTON, "subtitledelayplus"); }
Case (ACTION_AUDIO_DELAY_MIN) : { SendAction(ACTION_BUTTON, "audiodelayminus"); }
Case (ACTION_AUDIO_DELAY) : { SendAction(ACTION_BUTTON, "audiodelay"); }
Case (ACTION_AUDIO_DELAY_PLUS) : { SendAction(ACTION_BUTTON, "audiodelayplus"); }
Case (ACTION_AUDIO_NEXT_LANGUAGE) : { SendAction(ACTION_BUTTON, "audionextlanguage"); }
Case (ACTION_TOGGLE_WATCHED) : { SendAction(ACTION_BUTTON, "togglewatched"); }
Case (ACTION_SHOW_CODEC) : { SendAction(ACTION_BUTTON, "codecinfo"); }
Case (ACTION_CONTEXT_MENU) : { SendAction(ACTION_BUTTON, "contextmenu"); }
Case (ACTION_SHOW_OSD) : { SendAction(ACTION_BUTTON, "osd"); }
Case (ACTION_SHOW_ASPECT_RATIO) : { SendAction(ACTION_BUTTON, "aspectratio"); }
push Repeat
IF ( RepeatCounter MOD 4 = 1)
CALL SendAction(ACTION_EXECBUILTIN, "PlayerControl(Repeat)");
RepeatStatus$ = "Repeat On";
ELSE IF ( RepeatCounter MOD 4 = 2)
CALL SendAction(ACTION_EXECBUILTIN, "PlayerControl(RepeatOne)");
RepeatStatus$ = "Repeat One";
ELSE IF ( RepeatCounter MOD 4 = 3)
CALL SendAction(ACTION_EXECBUILTIN, "PlayerControl(RepeatAll)");
RepeatStatus$ = "Repeat All";
ELSE {
CALL SendAction(ACTION_EXECBUILTIN, "PlayerControl(RepeatOff)");
RepeatStatus$ = "";
RepeatCounter = (RepeatCounter + 1) MOD 4;
push Shuffle
IF ( ShuffleCounter MOD 2)
// OFF
CALL SendAction(ACTION_EXECBUILTIN, "PlayerControl(RandomOff)");
ShuffleStatus$ = "";
ELSE
// ON
CALL SendAction(ACTION_EXECBUILTIN, "PlayerControl(RandomOn)");
ShuffleStatus$ = "Shuffle";
ShuffleCounter = (ShuffleCounter + 1) MOD 2;
CHANGE LogMessage$
String responseLine$[ 500 ];
responseLine$ = Gather( "\n", LogMessage$, GATHER_TIMEOUT );
IF (LEN(responseLine$) = 0)
MAKESTRING(responseLine$, "%s", LogMessage$);
CLEARBUFFER(LogMessage$);
CALL SendLog(LOGNOTICE, responseLine$);
CHANGE Notification$
responseLine$ = Gather( "\n", Notification$, GATHER_TIMEOUT );
MAKESTRING(responseLine$, "%s", Notification$);
CLEARBUFFER(Notification$);
CALL SendNotification("******** System says:", responseLine$);
CHANGE WindowName#
// ActivateWindow parameters: http://wiki.xbmc.org/index.php?title=Opening_Windows_and_Dialogs
// and http://wiki.xbmc.org/index.php?title=Window_IDs
String Command$[ 100 ];
MAKESTRING(Command$, "ActivateWindow(%d)", WindowName#);
SendAction(ACTION_EXECBUILTIN, Command$);
CHANGE WindowName$
MAKESTRING(Command$, "ActivateWindow(%s)", WindowName$);
Main()
Uncomment and place one-time startup code here
(This code will get called when the system starts up)
Function Main()
WaitForInitializationComplete();
// If you are reading any Input or Output variables, uncomment
// the WaitForInitializationComplete statement above and read
// them afterwards. Input/Output variables will not have
// their correct values set until after the logic processor
// runs and propagates the values to them.
UniqueToken = GetTicks();
Dealer Name:
System Name:
System Number:
Comments:
***** License *****
#PRINT_TO_TRACE
#ENABLE_DYNAMIC
#DEFAULT_VOLATILE
#ENABLE_TRACE
_SKIP_;
Global Variables
Functions
,HeaderStart$
ELSE
/* SendHelo - */
,DeviceName$
CALL Send(PT_HELO);
FUNCTION SendBye()
PayloadLength = 0;
CALL Send(PT_BYE);
FUNCTION SendPing()
PayloadLength = 0;
CALL Send(PT_PING);
/* %c - log type */
/* %s - message */
,Chr(LogLevel)
,Message$
CALL Send(PT_LOG);
/* %s - caption */
/* %s - message */
,Caption$
,Message$
ButtonCode = 0;
IF (Amount > 0)
,Chr(High(Flags))
,Chr(Low(Flags))
,Chr(High(Amount))
,Chr(Low(Amount))
,DeviceMap$
,Button$
/* %c - flags */
PayloadLength = 9;
,Chr(MS_ABSOLUTE)
,Chr(High(X))
,Chr(Low(X))
,Chr(High(Y))
,Chr(Low(Y))
,Chr(Action)
,Message$
Delay(5);
Event Handlers
PUSH Connect
WHILE (Connect)
// 30-sec wait
DELAY(3000);
PROCESSLOGIC();
IF (Connect)
CALL SendPing();
RELEASE Connect
Delay(50);
CALL SendBye();
PUSH Up
PUSH Down
PUSH Lt
PUSH Rt
RELEASE Up
RELEASE Down
RELEASE Lt
RELEASE Rt
CHANGE Command
Switch (Command)
push Repeat
ELSE {
RepeatStatus$ = "";
push Shuffle
// OFF
ELSE
// ON
CHANGE LogMessage$
CHANGE WindowName#
CHANGE WindowName$
Main()
Function Main()
is there something specific that you need to convert to Netlinx code? A function for example?
,HeaderStart$
You can do it directly by assigning the lower 8 bits of an integer directly to a char.
For example you have the Integer PacketType and you assign to it the Hex value $3132.
If you want to transfer the 2 bytes (High and Low) of the integer to a Char directly you have:
CHAR sTemp[2]
INTEGER PacketType
PacketType = $3132
sTemp = "(PacketType >> 8),(PacketType & $FF)"
after the code executes the sTemp will have the string "12" as a value
