USB - RS232 device
So I am trying to use a new USB to RS232 device on my laptop and im not sure which port it is or if the port is even coming up on Netlinks when I try to connect to my master. I only have 4 USB ports on my laptop but when I go to Netlinks and try to connect I select Serial connection and only port 3 4 5 7 show up. Does anyone have an suggestions?
if so, try using "Windows XP mode " from Windows 7. Works for me!
Plug the SERIAL end of your converter into any SERIAL IO port on the NetLinx (MOVE it from the PROGRAM PORT to an IO), then attempt to send keystrokes out your terminal program... you will see the yellow light on the FRONT of the NetLinx corresponding to that serial port if any data is arriving... regardless of baud. It won't do anything but indicate that bits are arriving there, but you want to verify that, at least, before you go on.
