New Iridium license
This is very very cool. Iridium have released a new licensing model - one price, unlimited number of iPad devices linked to a single master serial number.
Brilliant idea! And best of all it's priced at a point where it be crazy not to include it in a system. It's called Ultimate.
Where can I get some tutorial or manual on how to PROPERLY use/setup that license???
I would call them and ask for some consideration.
It also eliminates the future UDID issues since the license is tied to the master but should a master crap out then in the aforementioned system you would need to update each of the 28 devices running iRidium. Since a master crapping out isn't that common I wouldn't be too concerned.
Still for the price of one AMX TP you can give a client unlimited possibilities. I guess it is a no brainer especially if it's equal to the TPC solution which doesn't even offer any PC control capabilities.
Vasiliy,
iRIdium Mobile has link on the there website to detail instruction how to setup and use their software. If you have a problem to find this link, that PM me and I will provide with direct link to this manual.
the8thst,
It is very good questions and right now (it is my opinion) in systems with multiple masters we only can use device licences. It it will be very expensive to use master license for each controller. The way how it works is if you don't have licence for the master, the panel (iOS/Win) will only receive messages and commands from the controller. NO button pushes from the panel.
As long as all TP devices are declared in the licensed master and the sub masters are being used for port expansion then everything works fine.
If the code is deployed across masters then it is more complex, I will let you know how this pans out.
Thanks Mkn. I've found pretty good/informative manuals on iridium wiki for amx. especially Video lesson is very useful...
Iridium may be the winner!
50 panels sounds like quite a bit to have all of the code residing on 1 master (unless you have 1 master dedicated to solely manage the panels).
OK we've done some testing with the Ultimate license and multiple masters and it works perfectly providing all client devices are defined relative to the Master with the Ultimate License.
Once declared, the TP code can be deployed on any Master within the system, just as with normal M2M setups.
I'm happy!
Ended up going with Command Fusion.
Working well with 50 iPods running at once.
