Strange TP problem
I have a rather odd issue with a NXD-500 touch panel. I load up the TPD design, and it displays fine on the screen and operates as would be expected. However, as soon as it is connected to the control system, some icons and text disappear completely. The text and icons that remain continue to function as expected. Has anybody else encountered such a problem?
If not, I would look at the TP file and be sure that none of the buttons are set to the system port (0).
Other than that my only other recommendation would be to remove all user pages and do a fresh full upload of the TP file.
I will try perform those steps and hopefully they resolve the issue, thank you!
Trade device numbers for the troubled panel and one that works. If the previously good panel behaves badly at the same device address as the "bad" one, it's being TOLD to do that... somehow... and not the panel's fault. If the "good" one is just as good at the "bad" address, and the "badness" stays with the "bad" panel no matter what address, the results should be clear.
By the way, your user name here is a bit off-putting....
