Servicing an old Axcent3
                                  in AMX Hardware
                    Hi guys,
ok so I'm working on making some changes to a customer's existing Axcent3. I can't upload the new program to the Axcent3 with NS3.3. It always fails. Front port/rear port - its the same. I CAN however upload stuff like new IR files with NS3.3
Bugger, so I fire up old DOS AXCESSX to open/compile and upload the new program in.
Has anyone encountered this before?
Cheers,
Brian
Cheers,
Brian
I think it has to be addressed to device 1 on Axxess systems. I was having the same issue not too long ago working on a Axcent3 system as well.
I guess that's what I get for not jumping on the AMX bandwagon until Netlinx was in full swing.
This Axcent3 has no DIP switches as far as I could see. The internal lithium batteries tested fine with my multimeter. I was able to set the bauds ok using AXCESSX. Device number is 1. Is there any known downward-incompatibility between our latest NS version and the really old stuff? Wierd since the IR codes downloaded just fine.
Brian
We were told for the time being you have to use File Transfer 2.
They are supposedly fixing it.
Thanks for posting the answer.
I guess it's a good thing I haven't upgraded yet.
I had to use File Transfer 2 for some old Axcent3 controllers.
