NI-4100 Slow on IR commands
atiofamerica
I am looking for an answer to a problem I am having with an NI-4100. We have had this job installed for about a year and a half everything has worked great. However on occasion the system will jam up and respond extremely slow on the IR commands. Some times it may take two minutes to give a command, then it will fire everything it has back logged in that time right in a row. Rebooting the processor does not make the problem go away, usually it returns to normal operation by the next day. Does anyone have any ideas on what I could do to figure this out?
Ben
Ben
I've been doing this for a little while now and I've never seen a system just 'go slow' on its own. I have seen a device's onboard memory start to get corrupted which caused some weird problems, but it was an Axlink IRS4 which was about 10+ years old.
RS232
-iPort iPod Dock
-Marantz AM/FM/XM tuner
-Auto Patch video switcher
-Auto Patch audio switcher
-Napco Gemini Security Panel
-RadioRa Graphic EYE
-PS Audio Power Controller 1
-PS Audio Power Controller 2
-B&K Surround Receiver
IP
-4 Proliphix thermostats
We are also using the Duet weather
Thanks for your help,
Ben
SHOW BUFFERS
If anything is staying there but ZEROS, there are commands backing up. It's normal to see some numbers come and go, but if you see the same or a climbing number across many seconds or minutes, it means things are waiting to exit. Many of them prevent other things from happening while they wait.
>Show buffers
Show Buffers
Thread TX RX Queued
Axlink 0
UDP 0 0-Sent=NO Waiting=NO
IPCon Mgr 0
Con Manager 0
Interpreter 0
Device Mgr 0
Diag Mgr 0
Msg Dispatc 0
Cfg Mgr 0
Route Mgr 0
Notify Mgr 0
Java Router 0
Total 0 0 0 GrandTotal 0
The AXLINK is the item you may see waiting. But it might be INTERPRETER, which means commands from the code are NOT being processed and are backing up. This can be due to code deadlocks or higher priority processes that are jammed, like a panel communication issue, about to go offline.
Are you sure the IR is getting delayed within AMX and it is not a problem with the controlled device?
I have seen DirecTV receivers with failing harddrives respond very sporadically to IR. The response time on a healthy DirecTV receiver fluctuates all over the map too.
Ben
I have had both Pool Controllers and Security systems cause this problem.
I finally made it back to the job site for some trouble shooting. I looked at the buffers, the Ax LINK buffers seem to climb/build rapidly then drop back to zero after a few minutes. It seems to me that when the buffers clear it can then fire the IR commands. I unhooked everything from the processor(Except the Ethernet), rebooted and the Ax Link buffers continued to do the same thing. Also, I powered off all Zigby devices, wireless TP's, and disconnected all IP control devices. I guess the only thing communication wise that I didn't turn off is the weather module. One more note is that it seems to happen in the evenings then everything works fine the next morning, all buffers at 0. Any ideas? I am on site today as well then I have to leave Sunday (Project is out of state) any help would be greatly appreciated.
Ben
Ben
At this point I would slip in another processor anyway to see if the problem changes. If not, it's something external. It's highly unlikely to be code...
The issue had to do with the latest firmware from AMX. The offending command was a basic IR setup command
SEND_COMMAND DATA.DEVICE, "'SET IO LINK 0'"
Even though this command set the IO link to the standard default and has been in working code for years, it now caused the system's AxLink queues to jam up and cause 2+ minute delays. This happened each time the system was rebooted.
