TPD4 + iPhone 4 (640x960)
Does TPD4 version 3.1.643 support the iPhone 4 (640x960)?
I’m still using version 3.0.0 Build 634.
I’ve been extremely leery of upgrading to 3.1.643 because of the horror stories I’ve read here:
http://www.amxforums.com/showthread.php?8113-Issues-with-TPDesign4-v3.1.643
None of the panel types in TPD4 3.0 has screen resolution of 640x960 and I don’t see any mention of 640x960 in the notes for version 3.1.643.
Thanks.
Thanks.
I don’t see any panel type that supports 640x960. You do?
You could patch TPDesign yourself, but I'm not sure if that works for the TPControl application
where they actively respond to support issues. As they've posted here many times, they do come here but not nearly as often as they are on their own support site.
Kostas
Or you edit the xml file containing all the devices, I've personally done that and this way it just says iphone4 for me
I've attached the configuration files for you, with a readme.
