iPort FS-23
Has anybody used the IP module for the iport FS-23 yet. I uploaded the program, but cannot get it to work. It just tells me the ipod is offline. I set a static IP and i can pull up the webpage for it. The virtual device is showing in the network tree. And I have triple checked my IP in the programming. Any ideas on why it wont connect?
    Try to PUSH channel 142 when entering in the page of the iPort. That channel is required for the communication to start. Alsp make sure to push channel 143 when iport control is no longer needed.
    Kostas
    bnealbneal Posts: 22
    Pushed channel 142. looks like it causes the module to initialize but does not recieve information fromo the module
    You have to install special firmware to get the FS-23 to talk over IP. It's on the Iport website.
    They aren't the best documented devices, let's say.
    arnmohanarnmohan Posts: 7
    JonRoss wrote: »
    It worked after updating firmware. many thanks jonross.
