KScape M500 Player (BluRay) with AMX 1500VG RGB Panel
I have an AMX 1500VG RGB Panel and I am trying to get the component output of the M500 Player working to the AMX Panel. The composite/s-video output of the M500 Player works great to the AMX panel but with the component output, I am only getting a quarter of the screen on the panel from the M500 player and the rest of the panel screen is garbage.
I know the AMX panel is ok because when I connect an Oppo BluRay player with its component outputs to the panel, the RGB works great.
I am trying to use the On Screen Display (OSD) of the KScape AMX module.
Does anyone have the M500 player's component outputs working with the RGB interface on an AMX panel ?
Any advice would be greatly appreciated.
Chuck
Chuck
Thanks John for the advice,
I went into the Video settings in Setup on the panel and I do not see where I can set the panel to 480i. I see 480P, 1080i, and some others, but no 480i which is what the KScape player will output.
Any ideas ?
