netlinx studio v2.x
                    hi,
Since the NS3.x has problem with TCP/IP for controller with some old firmware, I need NS v2.x. However, I can't find the latest v2.x from Archive page on AMX application files. By any chance if someone know where I can download the NS2.x?
Aldous
Aldous
http://www.amxforums.com/showthread.php?8110-AMX-not-receiving-data-string-event-from-TCP-connection
In fact, I have NS2.1 but I believe that it is not the latest of 2.x. I'm hoping to get the latest version in v2.x
Have you called or emailed AMX tech support? I don't see why they couldn't get it to you, unless you don't have a valid dealer number.
AMX support will put it on the FTP server for you to download.
Long answer:
What you are saying is this:
1) You're not a dealer.
2) You don't have a dealer.
I see two very simple solutions:
1) Call AMX and ask them to refer a dealer to you. This dealer will not (read SHOULD NOT) give you the software, but instead fix your problems.
2) Become an AMX dealer yourself.
What I am super curious about is, if you're an end-user, how do you have access to the downloads? Seems very fishy to me and not kosher.
mpullin wins the Internet!
I might add, even if your hardware is ancient, you can get cheap masters on eBay that are current.
