RTI and AMX Integration
Hello,
I see a number of dealers have done this in the past, and we just finished our first one - and I am having an issue and wanted to get some other peoples feedback on it.
We have an RTI U2 using the AMXRF trigger codes from RTI to talk to an AXR-RF. The system works pretty well, but sometimes it receives the wrong channel code, by 1. For example a code 24 may be received as a code 25. This is especially frustrating when it is volume or channel up and down which are next to each other, and it goes the wrong way.
It seems to improve after rebooting the receiver, but creeps back in. Has anyone else seen this particular issue? Any suggestions would be appreciated.
Thanks!
Thanks!
Sent from my iPhone using Tapatalk
I used a U2 and AMX 433 gateway and had similar issues. I traced it back to the position of my gateway. It was in the ceiling near other rf gear (wifi and telephone receiver) as well as being on top of a light balast. I'm not sure what the culprit was but moving it away from that location made it stop.
It was strange. Everything was coming across as an even channel. 1=2 and 2=2........
Let a = b
Therefore a^2 = a*b
Therefore a^2 + a^2 = a^2 + (a*b)
Therefore 2(a^2) = a^2 + (a*b)
Therefore 2(a^2) - 2(a*b) = a^2 + (a*b) - 2(a*b)
Therefore 2(a^2) - 2(a*b) = a^2 - (a*b)
Another way to write 2(a^2) - 2(a*b) is 2 * (a^2 - (a*b))
Another way to write a^2 - (a*b) is 1 * (a^2 - (a*b))
So 1 * (a^2 - (a*b)) = 2 * (a^2 - (a*b))
Divide both sides by (a^2 - (a*b))
Hardcore proof that 1 == 2.
If 1 equals 2, it cannot also equal 1. That's just crazy talk.
What is a=0? Then you are dividing by zero, and we all know what happens when you do that. Somewhere a kitten dies.
In the scenario I experienced when the RTI remote triggered AMX RF code for channel 1 the gateway would recieve it as a 2. When the RTI sent a 2 the gateway received it correctly as 2. When RTI sent a 3 it was recieved as a 4 and when it sent a 4 it was received as a 4.
So all the odd channels were getting bumped up to the next channel number.
It didn't happen all the time but when I moved the gateway it stopped happening altogether.
