ENV-VST-C Thermostat Wiring Recommendation for Testing Purposes
I have a ENV-VST-C thermostat that I just received.
I want to see how it works in a non-production system.
I connected the AxLink (4 wire) to my Netlinx 4000 master, but the thermostat does not power up.
I assume I need to connect a 24V AC power supply (RH and C connection points ?) , but I wasn't sure.
I am just looking to learn about the thermostat and will eventually put it into a system.
Any advice would be greatly appreciated.
Thanks!
Chuck
