TPDesign4 doesnt startup on my Windows 7 PC
                    It used to work! but now when I try to open TPdesign4 its looks like a program is about to start (spinny circle thing), and then nothing! have tried reinstalling, reinstalling in compatibility mode. Any help much obliged?
yes tried admin no luck
Faulting application name: TPDesign4.exe, version: 3.0.0.634, time stamp: 0x4c76de1b
Faulting module name: TPDesign4.exe, version: 3.0.0.634, time stamp: 0x4c76de1b
Exception code: 0xc0000005
Fault offset: 0x00166fea
Faulting process id: 0x5e4
Faulting application start time: 0x01cce7356f83e1a0
Faulting application path: C:\Program Files\AMX Control Disc\TPDesign4\TPDesign4.exe
Faulting module path: C:\Program Files\AMX Control Disc\TPDesign4\TPDesign4.exe
Report Id: ad7a4720-5328-11e1-939b-782bcbdfd396
I am successfully running all AMX apps on a Win7 64 bit machine - just installed and they ran, maybe uninstall and try again - sorry no magic answer
If that fails try installing into a different folder and make sure the shortcut is pointing at the right file.
all gave the same result i pasted earlier.
any other help is greatly appreciated. Studio runs fine.
My next guess is that there is a corrupt dll that is not being removed or overwritten on reinstall but i would not mess with deleting dll's unless i was instructed by AMX support.
More guesses...
Maybe your anti virus program is messing with TPD4
Maybe it's related to the graphics card or driver
If you are installing off/to a network drive or synchronised folder, or the default project folder is a network/synchronised folder then try not using it.
Try a different version of TPD4
Sometimes permissions get goofed up when the installer tries to make a new folder but the OS doesn't report the error back to the running process. So, the installer happily moves on even though the file it just installed cannot be accesed when the program tries to run.
Stoopid computers...
I'm suspecting that there's a system file version dependency issue with msvcrt.dll or other file on your machine.
For what it's worth, I installed over my old TPD4 on Win7/64 without incident.
I moved the SETUP out of the ZIP, right clicked on it and did RUN AS ADMINISTRATOR, and all was good.
