Led Video Processor 603S+
Hi all,
There's anyone can help me to solve this problem ?
I want to control LED Video Processor which using RS232 port the product is LVP603S+
this is link for your guide
http://www.videowall.cn/en/Downlist.asp
I think this product doesn't have good documentation, maybe someone have experience communicate this product with AMX, please share with me.... I need your help
I have try this command :
Thanks and regards
Novi Andriyansyah
Indonesian ACE Programmer
send_string (device),"'zzmkxxxxxy',$0D" <-- this command for VGA outputresult is "device no respond"
Thanks and regards
Novi Andriyansyah
I have Verified the Baud rate with 4800 with this step : for verify the notification from AMX, I was use telnet and notification in netlinx
from telnet : and I received : note:
If I took baud 4800 and I send any command I have no feed back if I send any command
if I took above baud 38400 and I send any command I have feedback from device FF FF FF FF FF FF
if I took baud 115200 and I send any command I have feedback from device FF FF a2trdj}FF DF
so anyone can solve this problem please share with me
For example:
Also, for code examples, please use the code tags as it makes it much easier to read.
[$code] <-- remove dollar symbol
Some code
[/code]
Hi James,
Unfortunately, until now I can't control that equipment
I have already moved "$0D" and try all baud rate but I don't have any result
regards
