Auto enable extended diagnostics info
PhreaK
I hate inefficiency and repeated tasks. Lately I've been finding myself typing 'msg on all' way to often and it sucks. I'm just wondering if anyone is aware of a way to auto enable diagnostic messages following a reboot on dev masters?
Write code that telnets the master to do it and trigger it from the define start section.
Having it scripted to auto enable as per the8thst is one option however on my dev system I use a serial connection to the program port so that I have a persistent console and don't need to reconnect after every reboot.
P.S. I know this is a true first world problem, was just curious if anyone had found themselves in a similar situation.
I like the serial idea for a dev system. I hadn't thought of that and my dev processor is about 5' away from my desktop, so I think I am going to make that change.
Are there 232/Terminal programs that let you write simple scripts ala IRC? You could then write a quick script to send "MSG ON" when "Welcome to Netlinx" was found on the incoming buffer.
It looks like you might be able to do it with data triggers in RealTerm: http://realterm.sourceforge.net/index.html#Data_Triggers
Docklight looks like another option: http://www.docklight.de/info_en.htm#dl_info_scripting
The problem appears to be that the RS232 session doesn't normally recognize when the master reboots so it doesn't recognize that the session is getting disconnected and reconnected. But, if I understand correctly, this is exactly why someone would want to use an RS232 connection for diagnostics/notifications rather than telnet.
With Indigo, jogging the session (hitting one button to stop the RS232 session and then the same button to restart it) takes about 1 second and this may satisfy people, I don't know. In any case, I prefer a telnet client for notifications/diagnostics. When the master comes back on line exactly one brief button click is all that is necssary to start up the telnet client and make the connection.
Amazing. I didn't know you could do that. Didn't know that I could do it either.
Thanks.
Seems that the ability to auto-reconnect a telnet session would obviate the need to use RS232 instead.
It was designed with AMX specifically in mind.
I'm sure with a little poking, the developer would add some feature requests.
I've been using it for a number of years but don't make use of very much of the features very often.
Just looked at the website and it appears that a beta release is available. Might be worth checking out.
I originally had Indigo installed on an XP machine and regularly updated it without any additional cost -- my installation was registered. When I bought a W7 machine and stopped using the XP machine, it was probably possible to get the license migrated but I figured that the small cost of a new license didn't really justify trying to get it on the W7 machine for free.
@svTech
For the auto-reconnect are you referring to the reboot sequence or is there a setting I'm missing somewhere.
Ok, when I have an active, connected Telnet session I see a number of icons in the lower right corner of the window. One of these icons is what I would call the connection icon. When connected, it's green and when disconnected, it's red. Clicking the icon changes the connection status and the color. Just to the immediate right of this icon is a small arrow icon. Click on this arrow icon and you will see a popup window with four selections, the bottom of which is "Auto-Reconnect". When I activate this, the connection indicates a disconnect when the master is rebooted and when the master comes back on line it indicates connected, the selected command is sent (as specified in the "send commands" tab of the session properties selected from the session drop-down menu). Also, when the master has been disconnected and the session is waiting to reconnect, a yellow icon appears in the upper right corner of the session window. I interpret this icon to mean that Indigo is waiting patiently for an ethernet connection so that it can reconnect the telnet session.
edit: Before finding this little auto-reconnect button, I looked through the session properties menus and could find no selection to activate the feature. Perhaps it's there somewhere (I think it should be) , but I couldn't find it.
The boards that I've seen have had debug written on the connector, both masters and touch panels.
Pins 2, 3 & 5 with a crossover.
115200, 8, N, 1
I made my cable using an old computer CD audio cable. The flat black 4 pin connector fits perfectly, just offset it by one pin so that the earth lead is on pin 5 of the board connector.
The auto-reconnect and the ability automatically send the MSG ON ALL command upon re-connect is very sweet indeed.
Sorry for being dumb here guys, but I have just downloaded Indigo and it does seem to be a better alternative to Telnet (especially the logging). i have seen how to set up the auto-reconnect, but have no idea how to send the 'msg on' command when auto rebooting.
Could anyone provide me with a shove in the right direction?
ManInBlack
Send Commands tab
In Auto Send Commands (on session connect) check Custom Command
Enter "msg on" in Custom Session Commands
or
Session Properties
Send Commands tab
In Auto Send Commands (on session connect) check Global Commands
Enter "msg on" in Edit Global Commands
Hi Colzie,
Thanks for the guidence on this one - I was totally stumped!!
Cheers,
ManInBlack
It works! How cool is that! Thats going to save me a problem . . . .
