NI-2100 - All LEDs lighted
in AMX Hardware
I was trying to load a new CF card to an NI 2100, but after loading the CF card , all the LEDs are lit up now. I am talking about link/act, status , input and output. In the troubleshooting section of the user manual, it says if all lit up, then the os is booting up.
Does it mean the CF card got corrupted. Does anybody have an image of a NI-2100.
I'd bet even if you throw in a new card, it won't fix the problem - but I hope I'm wrong!
Thanks for the support. The mistake i made is that i removed the screws on the sides instead of the ones on top.
Now when the screws are removed and the controller is connected to the CF card, the controller is working normally . If i screw them back, the controller is in a frozen stage (all leds on).
Happened to me years ago on an alarm movement detector and spent about 2 months trying to track down the cause until I realised that my offsider changed the sensor over and used a larger screw to fix the case, hence there was a short that manifested itself into false activations.
"AMX Tech Support. How can I help you? ... What seems to be the problem with your NI-2100? ... You say you electrocuted someone with it? ... Yeah, that's not covered under the warranty. ... No, I'd recommend you just call an ambulance..."
