Feature Requests for next version of TP Design
I am working on a touch panel file and here are a few things I would like to see in the next version of TPD:
File compare - Compare two different TPD files to see the differences. It would also be nice to be able to have a check box list of pages/buttons/resources to add/remove from one file based on the difference.
Grid Alignment - When selecting a group of buttons, brings up a dialog asking for number of columns or rows, layout direction (top to bottom, then left to right or Left to Right, then top to bottom), and spacing between buttons in pixels.
Other information overlays - This would be just like the Show Address/Channel info button, but I would like to overlay Feedback, Page Flip, Hidden/Disabled, Touch Style, or Draw Order, and Z-order(if possible). These should all be separate buttons in a toolbar and would be used to quickly visually verify a page layout for proper button programming.
Multi Cut/Copy/Paste of Pages and Sub pages in the project or between projects
Clean up Unused Icons and Bitmaps from a TP4 project if these are not used somewhere in the project
Kostas
Scalable, stretchable bitmaps.
A way to select and edit a button that isn't on top already.
Just a thought,
One request would be able to select a group of buttons and to be able to tab through them - much like when using a Windows program and you can tab through the different controls (text box, radios, buttons, etc.). I'm a keyboard kind of person, so I'd like to tab through the buttons and quickly enter in the text I want, or the property I need changed without touching the mouse.
Another thing I'd love to have is the ability to add folders to the file structure. Currently, in order to organize your images, the easiest way to do it is to prefix them with something. For example, all TV logos start with "tv_" then the name, or all icons are "icons_", or weather images are "wx_", etc. etc. I'd love to be able to import them into a folder, and select from there - much like a real file system. This might be a firmware & TPD4 change though . . . unless the firmware can already handle folders, and it's just up to the XMA file to say where it is (which I'd imagine is the case.)
A file merge feature. How many times, have you gotten panel pages from a third party and had to painstakingly copy and paste each individual page, and each popup, then go through all of them and edit the address, channel, and level port? Instead it should go like this:
* Merge <panel> into current (perhaps as an Import with merge/replace as options)
* checkboxes to scale elements if needed
* checkboxes and fields to convert ports on new panel to xxx while merging
* Option to rename/replace existing graphics with new of the same name
