NI-900 LEDs KEEP ON BLINKING WHEN I ON.
Hi,
I have a new NI-900, when I put power on it the 3 LED light just keep on blinking.
Is there any problem with my NI-900?
Please help.
Please help.
That's kind of an old reference, but I don't think they've changed it. The Link light also blinks, but not at a steady rate; it varies with activity.
It's been blinking for too long. I keep it ON for almost 1 hour and still it's blinking.
By the way, the LEDs that keep on blinking are the STATUS, INPUT and OUTPUT.
Is there any other reason why it keeps on blinking other than the "OS is starting"?
Have you tried to telnet into it using the program port (rs232)? If you get in you can try cleaning the disk and a lot of other things to see what's going on. but honestly, I think I see a call to AMX tech support in your future...
I hope it's not the one they called on the other thread as the "RMA lights"
Nope, the RMA light is a surface mount LED on the board itself. You have to open the case to see it.
If this happen? Is there any way to fix it or you have to send it to AMX?
I tried the all connection, RS-232, IP, telnet... Still it's fast blinking and can not connect to the controller.
time to snd i in.
I'm pretty sure it's toast if the power gets interrupted at that point. Part of the firmware goes to the CF card, and another part to non-volatile RAM, and the RAM is where the bootstrap is, do if it gets corrupted, it won't boot.
Yes, send it in to AMX.
The problem was the power supply. Change new power supply and it's working now.
