22-26 IN DISPLAYS WITH RS232
anyone know of any manufacturer that has a smaller 22-26 in displays that have rs232 ports. I am having a tough time finding anything
Just keep in mind that you might need to contact Sharp Technical Support to enable the RS-232 option. I am not
sure but i think the Integrator who hired us had to switch on the TV set in a special mode in order to boot it in a
hidden setup menu. And in that menu he changed some Hex values.
The other option is a Panasonic Viera and use the 3.5mm service port - it's not advertised as a RS232 port, but it is.
Simon
Sharp has the LC-26SV490U. I have no personal experience with that specific monitor, but I've never had an issue with the larger Sharp consumer displays that have 232 ports.
-Ryan
The RS-232 in the sharp aquos stuff is accessible from the Hotel mode menu, if you need a copy of the doc, get in touch. Infact tweaking some of the hotel mode entries greatly increases the reliability of working with an AMX controller, especially if you are stuck using IR and not RS232.
