NXB-CCG Netlinx Clear Connect Gateway
in AMX Hardware
I don't have one of tehse boxes in front of me yet, and am trying to prep for them. Does anybody know how these boxes connect to the master? Going through the manual and the module it looks like they are just IP appliances not ICSLan boxes. So I assume I'll have to manage the online/offline connectivity of them.
Has anybody worked with them before (and not used the module)
My thoughts exactly. The module doc just shows the device defined at 0:3:0. That is the only real clue that I've found so far.
I wish I knew weather it would stay connected once connected, or if I'm going to have to constantly open and close the port for polling.
I find that really true with the RMS stuff.
Then the age old question, do spend time writing code to talk to the AMX module or do I write my own? Any input would be appreciated.
"Opps* guess I didnt scroll down far enough in the manual the first time. I see it does support #OUTPUT commands. Now just for the "age old question"
Because it's not an AMX device. It's a Lutron device.
i.e. would MRF2-600M work or only the AMX CCD-6D?
Similarly with the counterpart occupancy sensor LRF2-OCRB2-P-WH vs the AMX CCD-OCRB-P.
