Ni-3000 Non-Responsive After Firmware Upgrade
in AMX Hardware
To get our old systems on RMS we need to upgrade the firmware. We did this to one of our NI-3100s and it's not been the same since. The Input, Output, and Status lights are solid and there's no connecting to it on the network; if it weren't for the lights you would think it was totally dead. Any ideas?
Let me know if you want a CF Image.
I can send to you by email.
joseanio@jpghh.com.br
CF image is a backup file from all of files and structure from the card flash. With this backup you can pick up the card flash form his socket inside the NI3000, Put this card on a USB card reader connected to your desktop or notebook , restore the backup to the card flash or a new one, put again on the socket inside the ni3000.
NI300 will boot again, you can connect ni3000 from the netlinx Studio and do a firmware update ....
something like this.
I have NI3000 CF image done with Norton Gost 11
Joseanio
Of course it's not quite *that* simple. You can try just switching the cards, but a portion of the boot code is in persistent RAM and not on the CF, and some combinations of firmwares won't work with each other ... so if your RAM firmware level is too far off from the CF firmware level, it still might not boot. But it's worth a try. Also, because of this mismatch potential, I think it's a good idea to reload the most current firmware once you have it up and running anyway, just to make sure all the components are on the same firmware.
I cannot access the controller in any way, at all. It's like it's not there.
I haven't been able to try a different CF card because we don't have one like I thought we did.
I appreciate all of your help. I'll keep trying.
