TP strangeness.
I have a MVP-8400 that is starting to act very strange. It's an older one so I might get 1- 1:30 hrs of battery life. When on the battery everything works as expected. When I plug it in I get no response from a button push. There are times where it will work, like the first button push after I plug it in. Is there some reasoning behind this? It has one battery in the 'Top' tray if that makes a difference.
Is the firmware up to date?
Did you try removing all panel files and doing a full upload?
Does it have a good network connection?
Tried two other power supplies working on a similar TP. Haven't physically tested the voltage.
Will check this weekend, haven't had the opportunity as yet. Thanks for the quick response.
E
What happens if you try to recalibrate? there is an issue that has been there for 'ever'. When you plug in the power supply, the calibration disappears sometimes. I could never get it to repeat with any regularity, it was random. I sent one off for repair, and the repair doc came back stating it was a 'known issue'
