HDMI Signal Sensing
Hi all,
First question:
Usually to sense if a DVD/Sky box is working i use a device similar to the AMX VSS2.
i have noticed that when using the DVX series web interface you can see if an HDMI siganl is locked or not.
my question is: is there a way to know this as a channel_event? it can then be used as a video sync sensor...
do we also have it on the DGX series controllers?
Second question:
if the Enova series have such control over the HDMI signal (EDID, HDCP, Smart Scale any input/output, etc...) why can't they give us simple control of the end product through HDMI CEC (on,off, inputs...)?
Ronen
First question:
Second question:
Ronen
I'm not intending to start spoofing internet connection, like ericmedley suggested, on an AMX device from the same AMX device(!)… this is something that is supposed to be built-in.
Anyone got any other ideas?
