can't compile anything
Hi. I'm having an issue with compiling, and I was wondering if anyone has had a similar problem or knows how to fix it. I just moved onto a Windows 7 machine from an XP laptop, and I haven't been able to successfully compile anything on the new computer. I even tried just compiling the netlinx template file without adding a single line of code to it, and I still ended up with the same problem. It says "C10201: Syntax error; Illegal or Invalid syntax in code", and no tkn file is created. Has anyone else had a problem like this? Thanks!
Also, make sure you have the latest version of Netlinx.
Finally, check out Tech Note 974: Windows XP Mode for Windows 7.
In the error it will mention the file that was being compiled when the error occurred, what file was that?
I have battled strange errors before only to find i have the wrong system acrive so check you are compiling what you think you are compiling.
