MVP-8400i and WPA2 problem
in AMX Hardware
Hey everyone, I'm having an issue with an 8400i dropping offline regularly on a network recently changed from WEP to WPA2 personal. The problem definitely seems to coincide with the network change. I haven't changed it back to WEP to confirm if the issue goes away. I applied the latest firmware to the panel last week with no change. WAP is a Cisco WAP2000. I found a setting on the WAP where it reassigns the PSK once every hour to the max setting (approx once per month). Any thoughts?
Thanks.
