Light bulb sensor???
troberts
Hello,
I have a client that is wanting to have his AMX panel show when a light bulb has burned out. I am wondering if anyone has done this and how. I am thinking I can get an amp probe at each light fixture and get a TED and monitor it or maybe get a bunch of AMX current sensors. Mt fear is, that when the light is dimmed I will get false reading.....Any other idea out there?
There's always Niles LS1 light senors or this from Xantech:
http://www.xantech.com/controls/controllersswitches/controllersswitchers/SMLIT01/
Thanks, I will look into that....I just wonder how much the sensitivity can be adjusted. So if the room has a lot of sunlight or other lights will the light sensor still think the bulb is ok....or if the light is dim, will I also get a false reading?
Any other ideas?
More advanced lighting systems (aka Lutron, etc) can alert you to a burned out bulb by sensing the failed current once power is applied.
In the low-end-DIY category you could try something like this: How to build an Arduino energy monitor.
Do you know if this is possible with Lutron Illuminations? This is what is currently installed, but I am unfamiliar with were or how this info can be polled for. Any pointer would be appreciated.
Sorry, I do not know.
https://www.sparkfun.com/products/11395?
Not directly, but it can be done. An Illumination system will report the dimming level, and if there is no load, it will come back as zero. So you could check the actual response against what you told it to do, though there would be some work in trapping that for the AMX. I can send you the protocol if you don't have access to it on the Lutron site (it's too big to attach to a forum message).
Depends on the dimmer. If it has a neutral, it will return what it's set at, now that I think about it in light of what you posted. But dimmers that don't have a neutral don't even have power if the load isn't there, so they report zero. Might be less than helpful to depend on it.
Perhaps you could use some of those old-school TV sensor boxes with your own coils??? Sounds like a fun day of tinkering.
