Code won't "stick" on ni-4000
in AMX Hardware
Hi all. I have an old ni-4000 that I got second-hand. When I first got it, I was able to upload some old code to it and everything seemed to work just fine. Now, however, I'm trying to upload the actual program I want it to run, but it doesn't seem to make it into the master's memory. I can connect to my master by IP and serial, and when I send my code, Netlinx Studio says it went just fine. I can also send TP4 files to my NXT-CV7 through that master, and the touch panel says its connected.
But.
My controller doesn't do anything in response to button pushes. The input light will blink when I hit a button on my tp, but nothing else happens. When I tried the ftp, the only thing that showed up was my IR file. When I go to the web interface for my master, it says "No program running". I've tried sending blank code to it and resending my program, and I've done clean disk, but I still can't get my code to "stick". Anyone have any ideas? Or do I just have a really big paperweight with pretty blinky lights now? Thanks!
But.
