RMS Enterprise hosted in the cloud.
Has anyone hosted RMS in a VPS and if so can you give the details please:
VPS Specs
OS used
Hosting service used.
VPS Specs
OS used
For the client -> server communication this is where RMS Enterprise and the v4.x SDK really shines. All clients communicate via a RESTful API. This is the exact type of traffic the majority of virtual hosting providers have engineered their platforms for.
Now, for the cons. The major one is that you have now introduced a whole bunch of additional network complexity between your clients and your server - a lot of which neither you, nor the client has ownership of. If service availability is of a concern this may be a deal breaker. If the pipe to this external provider goes down, you've lost all monitoring and data acquisition. If there are internal issues within the provider you've lost all monitoring and data acquisition. If the provider has a service outage you've lost all monitoring and data acquisition etc. However, the flexibility, reduced setup, operating costs and overheads a 'cloud' based solution provides may outweigh this. As an integrator its ultimately up to you to specify the optimum solution for the deployment requirements. RMS has the flexibility to provide you these options though.
TL;DR
Virtual hosts work great (including external aka cloud), however remember the hosting platform is just one component of the overall solution.
