Vivitek Projector over IP?
Having to control a Vivitek projector that got substituted because of a discontinued model. I've found an RS-232 control protocol, but no mention of IP control, and I don't have a good way to run serial to it. It has built in network control for Cre$tron 'Room View' software, and I'm curious if anyone has ever run across any of these and had success in controlling them from AMX over IP? I guess worst case I have to buy an Ethernet-->serial box of some sort, but I'd rather not have the crew have to bring a lift back in to access it. I'm playing with the web control gui on it to see if I can write something to just power the thing on/off via html, but I have no experience controlling things in this manner. Any thoughts?
Don
Don
Try using Telnet client (Hyperterminal, etc) on port 23 to send the RS-232 control strings in the control protocol doc. I have seen this type of control capability on other devices. Telnet to the device IP address, then just do the string <CR> to see if it will respond.
I use "IP Network Scanner" (I think on my iPad) you can scan the network to see what on it and then select a specific IP/device and go > advanced > port scan, to see its listening ports.
I did some work with them a couple of years ago and I know this was the case with at least one model.
To help you with IP, I vaguely recall it needed to be enabled within the setup menu, as some sort of RS-232 over IP configuration. It was a couple of layers into the setup menu.
I was able to use RS232, but once powered off even using RS232, the Power On does not work!
Also could see apparently only Cre$tron can talk to it via http.
As I did not want to go to the Wireshark route, I recommended my client to get another brand of projectors - especially after I saw their web site for Tech support was down when I needed to contact them.
Wow, that is a terrible feature...as I'm going to have to add an IP-232 box to make this work, I really hope they have that sorted out. This is a stage display/confidence monitor short throw setup off the front of a balcony in a large church, and all I really need out of it is power on/off and input selection between VGA and HDMI. I can definitely do it all from the web gui, so if push comes to shove and serial won't power it on, I may have to learn how to do HTTP control. Any advice if I have to go this route?
Replacing the projector is a last resort as it is a terrible position to reach and it was hard finding anything that would do the job required, as this is replacing a Panasonic that would not fill the screen despite what their lens calculator says.
Sucks to be bogged down on such a trivial component of a huge job. Got IP control of the 6 Christie Roadster HD14K-J main projectors no problem, and I'm spending way too much time working with a cheap little short throw guy.
I don't think you want to set up that lift a 3rd time, right.
Hi Don,
I think that all of projectors with ethernet port are PJLink compliance, so you can use AMX JBMIA MODULE, and you never more wont need write code to control projectors. Could change the projector brand and only setup the ip and done. You could control several projector brands with the same code.
http://www.amx.com/inconcert/ct/DevMdlDetails.asp?A=Sh&MdlNo=29338&MdNo=0&DLM=1&lk=522D2EAD-6321-4915-8FBB-258A3AA7&FPMSN=
http://pjlink.jbmia.or.jp/english/
