DXLink
More new shiny things!
The info currently on the AMX site about this is extremely light on. Can any shed some light. Is this an incarnation of HDBaseT or is it a proprietary distribution system?
From the AMX product page
and from the HDBaseT spec
http://www.amx.com/products/categoryNewProducts.asp
Twisted pair, 300 feet, full HD, with control. Wonder if it would care to run over leftover coax?
EXPENSIVE. You need a transmitter and receiver, sold separately, each around the price I'd have thought for the pair...
I have setup a standalone system with DXlink transmitter and receiver from out of the box, i get to pass the RS232 signal but the HDMI video were also shows a green image. Is there any configuration to be made, DIP switch were set to all off. any suggestion,
The first release firmware output a green image when connected to an unknown device and you had to set dip switch 4 on when connecting to a DVX-3150. Subsequent firmware releases have overcome this though.
BTW - you should really start a new thread rather than raising the dead. This thread was dead for 20 months before your post.
thanks,,, firmware is updated. but dip switch 4 to on has never tried yet... I am using DVX-2155 and also have problem on hdmi output 1, it does not pass bluray signal but on dxlink output 3 it passes,, any thoughts on this,,,
thanks again..
Does anybody know is it possible to turn DXLINK's power ON and OFF using SEND_COMMANDs?
I only find how to reset DXLINK: SEND_COMMAND DXLINK01,"'REBOOT'". The power comes via POE from Enova DGX-16, maybe it is possible to switch somehow the output voltage in Enova?
I don't think so. What I do is put all my outboard boxes (Panels, EXB and DXLink) on a separate POE switch, then put that into a Furman power center with network control. Then I can use that to power cycle them. Anything that needs to power cycle separately gets it's own POE and outlet.
Take a look at this Dave:
http://store.blackwiredesigns.com/12-Port-Gigabit-High-Power-POE-Injector-_p_218.html
Each PoE port can be power cycled individually so you don't drop the whole network just because one device falls offline.
I'd post a price for you, but someone at the office must have used the "I Forgot My Password" thing and now I can't login... sales people... enough said.
I think Pakedge just introduced something similar, and that is our network gear of choice these days. I'll have to shoot that over to sales in the event it will work better for us. In this trade, there is no such thing as having too many tools.
Here's another product you might fancy, an 8 port midspan rack mount injector but not a switch, in & out and controllable for $295.00. It also has autoping to automaticlly cycle power if a connected device doesn't respond. Their power strips have the same capability and what I've been using for years and again is only $295.00 for 2 circuit rack mounted power distribution, 16 outlets, (8 individually controlled pairs).
http://www.digital-loggers.com/poe48.html
DXLink transmitters and receivers should not be connected to Ethernet switches (PoE or otherwise) via the DXLink port. DXLink does pass Ethernet data and PoE over the standard pairs but in addition also utilises the additional pairs which are unused in an Ethernet environment.
DXLink transmitters and receivers will powers up if the DXLink port is connected to a PoE switch however, if the DXLink port on a device is connected to anything other than a DXLink port on another DXLink device (e.g., DVX, DGX, TX<->RX) the unit will automatically fall back to Ethernet only mode. While Ethernet will pass through the device in this case there will not be audio or video.
You should only connect the DXLink port on a DXLink TX/RX unit to the DXLink port on another DXLink device (e.g., DVX, DGX, TX<->RX).
You can use specific PoE injectors in-line to power the DXLink device but you should only use PoE injectors recommended by AMX (engineering has seen that damage can occur if using non-supported PoE injectors resulting in a dead DXLink device).
Supported PoE injectors include the PS-POE-AT-TC and the recently released PDXL-2.
The PDXL-2 is a duel power over DXLink controller which allows you to power 2 x DXLink devices from a central location (ideal for TX-RX point-to-point applications where locally powering the units is not possible) and in addition accepts IO control from a NetLinx master allowing you to shut the power off to each DXLink device if required.
Hope this helps.
