MVP-7500 Failed Firmware Update
in AMX Hardware
I bricked a MVP-7500 a while back during a firmware update. Update nearly completed then touch panel power cycled itself - no I was not touching unit when this happened. I was actually dressing some cables in the AV rack and watching the update progress at same time. I believe the problem is Compact Flash related. Does anyone have an image for firmware version 2.86.41? This is the version I was upgrading to when this happened. Since the update was nearly complete I am hoping the flash chip is updated and OK and the problem is the complact flash. Customer purcahsed a NXV-300 to replace the old MVP-7500. Unit wil turn on but will not boot past the AMX logo screen. Any other pearls of wisdom or ideas to fix are highly encouraged and will be highly appreciated.
