Proliphix thermostats
After extensively working with Proliphix on both their NT and new IMT series network thermostats we have written a newer module that can handle both series on the same system. Apparently when they made the new IMT series they decided for some reason to change the http authentication from Basic (which is easily done in Netlinx) to Digest (which can only be done in Java). We spent tons of time and money as we had all our projects with the new IMT stats installed already. If any of you are in need of code for either series contact me directly as I don't check these Forums very often anymore.
paul@d-e-g.com
    Is this still the case or can authentication be done w/o java?
