Sony BluRay Protocol (BDP-BX59)?
A client picked up a Sony BDP-BX59 BluRay player at Costco or some big-box store. Does anyone know if this is controllable by IP and if there's a protocol document anywhere? I need to write a module for it.
Thanks!
John
Thanks!
John
http://files.remotecentral.com/view/77-235-1/sony_bdp-cx7000es_blu-ray_disc_player.html
So now the fun begins
I didn't get a chance to test network controls on this device, so I just tossed IR control on it until I have access to the device.
Here's the IR control info if anyone needs a simple way to control this BDP or similar. The code below assumes you've aligned your TP channels with the IR channels. The irl file (SONY0593.IRL) is in the AMX database.
--John
BUTTON_EVENT[tpBDP_SONY,0] //Button Press - ANY { PUSH: PULSE[dvBDP_SONY,button.input.channel] } (* IR FIle: SONY0593.IRL Device: SONY BDP-S790 Remote: RMT-B122A Compatible with BDP-BX59 Match the Touchpanel Channels to the functions below: CH FUNCTION 1 Play 2 Stop 3 Pause 4 Next >>| 5 Prev |<< 6 Scan >> 7 Scan << 9 Power 10 0 11 1 12 2 13 3 14 4 15 5 16 6 17 7 18 8 19 9 44 Top Menu 45 Cursor ^ 46 Cursor v 47 Cursor < 48 Cursor > 49 Enter 54 Return 57 Subtitle 58 Display 80 Open/Close 89 Audio 111 Red 112 Green 113 Blue 114 Yellow 115 Pop Up Menu 116 Input 117 Home 118 Options 119 Netflix 120 SEN 121 3D *)
