Activating the Pink Noise thru Control
Using RTI APEX. I have a London BLU-102. on the fence to use serial or ethernet. Where do I find the Pink Noise?
Best Answer
HARMAN_icraigie Technical Trainer II, Harman Professional University Posts: 568
Noise Generator is a processing block found in the tools menu. Hex-string to set Pink Noise
02 88 79 80 1B 83 00 01 19 00 01 00 00 00 01 6A 03
// Program dependent addresses
Node = 79 80
Object = 03 00 01 19
// Object addresses
Parameter = 00 01
Data = 00 00 00 012
Answers
Im assuming that is on??? Is there a off string??
The Noise Generator only has White or Pink selection. On or off would have to be handled by the block where that signal is brought into the system (mute, source selector, etc.)
hi
