Link gain values
I have 3 BLU-806 interconnected at same LAN. My question is. Does it possible set a value on Gain object and at some manner other gains assumes the same value ?
This can be done. Create an "exact" link. Open the first object you want to link. Drag-and-drop the "new parameter link" on to the gain control. This will now populate the link objects list. Open the next gain object from the other 806 and do the same thing using the parameter link from the first step. Both items will now follow one another. Keep doing this as many times as you need for your design. This all assumes that all the 806 units are in the same Audio Architect design.
