morphing eq gains to rotary
imsausage
Is the a way to morp or link gains and freq controls from eqs to a rotary knob like on a 9088?
any word on the release of the software with macros?
Carl Sagen
Carl Sagen
There is not a morphing option as in soundweb green (where you right click on the fader and select Morph)
The quickest way is to
-select a graphic rotary and place it into a custom panel
-go to the gallery and select 'bitmap/bss/rotary (then select the rotary style from a list.
-select the rotary and go to 'properties' to display scale info, etc.
-Layout the rotary objects as per your design requirments. (select/copy and paste)
- go to the design tree, find the gain or EQ you wish to place on the encoder, select and drop onto the relevant control.
- You can also save the layout of the rotary objects in the gallery for future use.
Not sure what you want to link, but this is done by selecting 2 or more like objects (eg gains), right clicking and selecting 'link' you can then select a soft or exact link.
If you need to add to a link in future, go to the design tree, scroll to the bottom, and all your links are listed, you can then drag and drop the other like objects in to a link.
You can also create a link on/off button by going to the link list in the design tree, selecting the link you want, and drag it onto a button on a custom control screen. This will then allow you to toggle the link on and off.
If you use the 'soft link' option, you can now create an offset (so the gains are different values) you turn off the link in the custom panel, create an offset, and turn the link back on.
Not sure when the next release is due, but think it is soon.
Hope this helps
Rob
