You don't. The eventlog monitor object only works on Crown pip cards.
Category – Event – String
16 - 1 - CobraNet audio dropout on YYY, bundle ZZZ
16 - 11 - TDH above limit on Channel 1
16 - 12 - TDH above limit on Channel 2
16 - 13 - TDH above limit on Channel 3
16 - 14 - TDH above limit on Channel 4
16 - 15 - TDH above limit on Channel 5
16 - 16 - TDH above limit on Channel 6
16 - 17 - TDH above limit on Channel 7
16 - 18 - TDH above limit on Channel 8
16 - 21 - Excessive Clipping on Channel 1
16 - 22 - Excessive Clipping on Channel 2
16 - 23 - Excessive Clipping on channel 3
16 - 24 - Excessive Clipping on channel 4
16 - 25 - Excessive Clipping on channel 5
16 - 26 - Excessive Clipping on channel 6
16 - 27 - Excessive Clipping on channel 7
16 - 28 - Excessive Clipping on channel 8
16 - 31 - Fault on Channel 1
16 - 32 - Fault on Channel 2
16 - 33 - Fault on Channel 3
16 - 34 - Fault on Channel 4
16 - 35 - Fault on Channel 5
16 - 36 - Fault on Channel 6
16 - 37 - Fault on Channel 7
16 - 38 - Fault on Channel 8
16 - 41 - Load below limit on Channel 1
16 - 42 - Load above limit on Channel 1
16 - 43 - Load below limit on Channel 2
16 - 44 - Load above limit on Channel 2
16 - 45 - Load below limit on channel 3
16 - 46 - Load above limit on channel 3
16 - 47 - Load below limit on channel 4
16 - 48 - Load above limit on channel 4
16 - 49 - Load below limit on channel 5
16 - 50 - Load above limit on channel 5
16 - 51 - Load below limit on channel 6
16 - 52 - Load above limit on channel 6
16 - 53 - Load below limit on channel 7
16 - 54 - Load above limit on channel 7
16 - 55 - Load below limit on channel 8
16 - 56 - Load above limit on channel 8
16 - 61 - Line Voltage Out of Range.
16 - 71 - Power Supply: Temperature above limit.
16 - 81 - Bridge Switch: Has changed positions on the channel 1-2 pair.
16 - 82 - Bridge Switch: Has changed positions on the channel 3-4 pair.
16 - 83 - Bridge Switch: Has changed positions on the channel 5-6 pair.
16 - 84 - Bridge Switch: Has changed positions on the channel 7-8 pair.
16 - 90 - component at max workload
16 - 101 - The Input Pot Position of Channel 1 is not within range of the preferred value.
16 - 102 - The Input Pot Position of Channel 2 is not within range of the preferred value.
16 - 103 - The Input Pot Position of Channel 3 is not within range of the preferred value.
16 - 104 - The Input Pot Position of Channel 4 is not within range of the preferred value.
16 - 105 - The Input Pot Position of Channel 5 is not within range of the preferred value.
16 - 106 - The Input Pot Position of Channel 6 is not within range of the preferred value.
16 - 107 - The Input Pot Position of Channel 7 is not within range of the preferred value.
16 - 108 - The Input Pot Position of Channel 8 is not within range of the preferred value.
That's actually a tough question. I can say yes, it's up to date, but that just means that you're looking at the most current information given to me by Crown. I've never actually tested these codes, so they may be completely wrong.
16 - 5 - Fault on Channel 1
16 - 6 - Fault on Channel 2
The reason your results are different to the list posted by Dan is that his list is for an 8 channel USP/CN based amp. These cards are totally different to the 2 channel card you're using which means the error mapping is very different.
Is this list still up-to-date?
What I am seeing using trial and error on a Cts2000 with a PIP2 USP3/CN with firmware 2.0.8.6 is:
16 - 1 - TDH above limit on Channel 1
16 - 2 - TDH above limit on Channel 2
16 - 3 - Excessive Clipping on Channel 1
16 - 4 - Excessive Clipping on Channel 2
16 - 5 -
16 - 6 -
16 - 7 - Load below limit on Channel 1
16 - 8 - Load above limit on Channel 1
16 - 9 - Load below limit on Channel 2
16 - 10 - Load above limit on Channel 2
16 - 11 - Line Voltage below limit
16 - 12 - Line Voltage above limit
Can anyone help me fill in the gaps?
Robin
Dan
Some filled in blanks for you;
Hope this helps.
Cheers
Martin
I was wondering if that might be the issue.
Thanks for rounding out my list!
Robin
